Clustering Point Feature Service
4355
01-21-2013 02:59 AM
KhaledEl_Shazly
Is there an easy way or a configuration to support clustering Point layer in ArcGIS Online or ArcGIS Explorer (Features to be grouped based on the scale of the map).
AndrewZimba
So... can this be done in ArcGIS Online yet?
RaymondHuang
As far as I am aware at v10.2, Point Clustering type of symbology is support via Web APIs instead of ArcGIS Online.
That is to say, you can achieve it, for example, through using the ArcGIS API for Javascript like this:
Info: https://developers.arcgis.com/javascript/jssamples/layers_point_clustering.html
Demo: http://developers.arcgis.com/javascript/samples/layers_point_clustering/
If you are looking at having it as one of the rendering option directly from inside ArcGIS Online map viewer, then perhaps we just need to wait a while more as the Idea is already under consideration due to the demand: http://ideas.arcgis.com/ideaView?id=087E00000004I7dIAE
Cheers
