Are custom URLs supported
2093
11
07-18-2017 08:01 AM
CarlHolt1
Currently using Collector for ArcGIS for viewing and created a Custom URL linked to Survey123, but when I use Explorer the fields are being populated with the data I have mapped out in the Custom URL. Is there something special I need for Explorer or is this capability not possible?
arcgis-survey123://?itemid=102b96d8619f4f58a6a71ec6974a596a&field:GRNWY_NAME={PROPERTY_N}&field:WATERSHED={CREEK_NAME}&field:GW_ID={GREENWAY_I}&field:GRNWY_TYPE={Fee_CE_Acq}&field:NOTES={NOTES}&field:SPEC_COND_1={SPEC_CON1}&field:SPEC_COND_2={SPEC_CON2}&field:SPEC_COND_3={SPEC_CON3}
by Anonymous User
Not applicable
Hey Carl Holt‌,
Are you still seeing this issue? We addressed the underlying issue that I referenced here https://community.esri.com/thread/198371-are-custom-urls-supported#comment-702777
This should be resolved in the current version of Explorer, with one caveat. Looking at the url you are trying to build, if there are spaces in the values that will be substituted into the url, iOS will cut this off in the Custom Attribute Display. To get around this, you can copy/paste that same formula into the URL of a hyperlink and the spaces will be percent encoded.
Joel
CarlHolt1
Yes the latest version resolved the issues.
