Labels in a Mobile Map Package
1304
02-21-2020 08:24 AM
PatrickRobb1
Does anyone know of any issues/bug fixes/workarounds for layers (that are turned off) in a mobile map package that still display the labels? The only way I have found to get them to turn off is to turn the layer on and back off. This is not very productive to say the least. This is happening with lines and polygons both. We can't convert everything to a vtpk as the staff will need to identify the layers underneath. Has anyone else had this issue and have a better workaround?
We are using:
  • ArcPro 2.5 - Creating the MMPK
  • 10.6.1 Server for the layers (if that matters)
  • Arc Explorer for windows - viewing the MMPK
Any assistance in this would be greatly appreciated.
PatrickRobb1
Update: You have to turn off the layers in the feature data set or group layer. Hope that helps
SebastienPelletier
I have the same problem with the IOS and Windows version. I also have labels that even,  if the layer is no longer visible, the labels remain on the map.
PatrickRobb1
WilliamRice
Occasional Contributor II
Yes, I also have the same problem with the labeling initially appearing in Explorer for iPad for just one polygon layer in the mmpk.  Toggling the layer on and off makes the label go away which suggests that this is an app type issue.   Have to do some more testing with just this one layer to try and see if this is a Pro issue or an Explorer for iOS issue.  Used ArcGIS Pro 2.5.1 to create the mmpk.
