support for dimension feature class in MMPK?
829
12-09-2021 05:17 AM
by Anonymous User
Not applicable
Does the MMPK format support publishing the Dimension Feature Class (does not need to editable, view only)? We need to have MMPK available offline to work in poor cell signal areas so the web map is not option for viewing dimension feature class.
Tags (3)
MarkBockenhauer
ArcGIS Pro 2.9 will include dimensions in a Mobile Map Package.  ArcGIS Runtime 100.13 (to be released very soon) will support viewing them.
So in short, the mobile map package needs to be created with ArcGIS Pro 2.9 and the application needs to be built on ArcGIS Runtime 100.13 or newer.   This capability will be possible as apps are built and released on 100.13... so not possible with the currently released apps.
MarkBockenhauer
by Anonymous User
Not applicable
Thank you for the details. I had a difficult time locating that in the documentation sites for Pro and the apps. Looking forward to supporting my users with Dimensions in the Esri mobile apps 😉
