At the moment you cannot edit or add records to a hosted table in Field Maps unless it is related to a feature layer. Lots of surveys require information that doesn't have a spatial element (e.g. weather conditions), and building it into a relationship is overkill.
It seems like a relatively easy win to be able to add a record to a standalone hosted table that has been added to a Webmap. Please could you enable it?
This would be massively beneficial to me and looks like an easy thing to sort out.
This, after two days of struggling with Arcade documentation and syntax. Looking into other solutions altogether now. Thanks @RichardHowe
Also, not just being able to edit a table, but also having the ability see the attribute table is a must and really critical for getting an overview of the collected information. At the moment, it is only possible to see a record at a time which non-productive.
