Hi everyone,
I am working with some GPS points that were collected in Field Maps using a high-accuracy GPS receiver. I need to know if the antenna height setting gets applied (subtracted from) to the altitude values in the metadata for the GPS points.
This article reports that the latitude and longitude in the metadata are directly from the GPS receiver and do not have datum transformations applied.
https://doc.arcgis.com/en/field-maps/latest/prepare-maps/high-accuracy-data-collection.htm
- Latitude—Position received from the GPS receiver before applying data transformations in the location profile
- Longitude—Position received from the GPS receiver before applying data transformations in the location profile
- Altitude—Ellipsoidal height received from the GPS receiver (not orthometric height, as used for z-values)
If that is the case for lat/long, wouldn't the altitude values also be directly from the receiver? If the antenna height does get subtracted, then I may have unnecessarily subtracted an additional 2 meters from my GPS points altitude values.
If anybody knows the answer to this question, I would really appreciate the help! Thank you!!
