Offline area download error
302
11-09-2023 01:50 PM
Laura
by MVP Regular Contributor
I am using the correct basement for export - seems only the portal admin is able to download the offline areas made online within any mobile device. Every other login fails and I am now also seeing issues with the layer loading with those logins. It seems i've been struggling with this apps for months, any ideas?
ChristopherCounsell
Can you give more info?
  • ArcGIS Online or Portal for ArcGIS? if the latter, what version?
  • Does this occur with no layers in the map?
  • What happens when it fails? screenshots, error messages?
  • Does the ArcGIS Field Maps web application show all the layers are offline-ready?
  • Have you looked at the logs in the server, field maps..?
Laura
- portal 11.0
- yes
- it just errors and then I go into the map and suddenly can't access the layer
- yes all offline as portal administrator login could download and do everything. There's just 1 layer
JoabelBarbieri
Occasional Contributor II
I found a big bug that was making offline maps fail to download and even failing to package in the Field Maps Designer. DO NOT USE VECTOR SYMBOLOGY !!!
Once I used Basic Symbols it worked again !
