Hi Field Mappers,
I'm writing in the forums hoping other people have come across this issue too (recently and solved it) without having to republish...
Problem:
I've added new fields, and now I'm not able to take the map offline.
The main error (I think?):
Error downloading map: Service error code 500: unable to create replica. Please check your parameters. Details: Exporting data for layer 32 failed. (Rest of the log attached)
So I've pinpointed the layer by going into the JSON. Based off of that I decided the other layers in the service are not the problem. I have also tested taking the other layers offline without layer 32. It worked. I tried adding layer 32 into its own map by itself and taking it offline. It didn't work.
I don't understand what's wrong with my parameters and how to fix them though. By parameters is that the feature service settings, Field Maps settings...?
I have also checked that I haven't added any fields using reserve words.
The feature service is live and people are using it, so I can't tinker (eg delete fields) too much with it, but am at the stage where I'm considering downloading it to FGDB, republishing and then removing each new field I added one by one, but am hoping someone might have a good work around for this?
These are older posts I found and tried, but didn't work for me.
Has anyone else come across this before and recently?
