Arabic Support for ArcGIS/Sharepoint
1650
11-03-2010 03:20 AM
ScottTansley
New Contributor II
I'm working with a business partner that wants to use ArcGIS Mapping for Sharepoint with Arabic customers, and has raised the following questions:
1) Whether the position of titles and toolbars can be adjusted
2) Whether ArcGIS for SharePoint supports right to left text
3) Whether ArcGIS for SharePoint supports Arabic fonts
4) Whether toolbars, tabs, tooltips, labels, context menus etc can be changed to Arabic text
Can anyone help please?
Scott
RichZwaap
Occasional Contributor III
Hi Scott:
I'm not sure exactly what you mean by your first question - the "toolbar" is integrated with the SharePoint ribbon and the title is part of the web part.  So the Map Web Part's ribbon tabs will be rendered whereever the SharePoint ribbon is.  You can move the ribbon by editing the aspx page's markup.  The title shown above the web part cannot be moved, but it can be changed or hidden.  Is this what you're asking about?
As to the rest, the answer is basically no.  Version 2.0 of ArcGIS Mapping for SharePoint cannot be localized.  We are planning to make 2.1 localizable, but right-to-left probably will not be supported yet.
JamalNUMAN
Legendary Contributor
Hi Scott:
Hi Rich,
I've a problem now with the arabic font in ArcGIS 10
While ArcGIS 9.3 can read the domain of a geodatabase written in arabic, ArcGIS 10 can't!!!!!
please, see the attached screenshots
how can i solve this problem?
i need to work with my old geodatabases (that contain domains in arabic) in ArcGIS 10
thank you in advance,
regards
Jamal
Jamal Numan
CarstenVock
Hello,
does anyone know if something has changed in 2.1.1 if Mapping for SharePoint supports arabic language now or if it is planned?
Thank you!
DerekLaw
Esri Esteemed Contributor
Hi Carsten,
... does anyone know if something has changed in 2.1.1 if Mapping for SharePoint supports arabic language now or if it is planned?
Yes, ArcGIS for SharePoint v2.1.1 now supports localization for Arabic.
FYI, What's new in 2.1.1
(look under the Localization section)
Hope this helps,
