The portal at <URL> is not configured to support Esri Maps for Office
9771
14
11-06-2015 03:05 PM
JohnDye
Occasional Contributor III
Hi Everyone,
I'm trying to get Esri Maps for Office up and running with our Portal. It seemed like a pretty straight forward setup. I installed the Portal Resources, restarted the Portal and then installed Esri Maps for Office 3.1 on my client machine and restarted Excel and Powerpoint.
When I fired up Excel to start testing, I noticed that I wasn't signed in automagically - which I thought was strange because our Portal is configured for IWA. So I clicked the Sign In button on the Esri Maps tab and got this:
Not sure what to do since it doesn't really provide any guidance as to what's wrong.
Environment
Server-Side
  • Server1 (Windows Server 2008R2)
    • Web Adaptor (IIS) 10.3.1
    • Portal for ArcGIS 10.3.1
    • Esri Maps for Office Resources for Portal for ArcGIS 10.3 or higher
  • Server2 (Windows Server 2008R2)
    • Web Adaptor for ArcGIS 10.3.1
    • ArcGIS for Server 10.3.1 (Federated + Hosting)
  • Server3 (Windows Server 2008R2)
    • Datastore for ArcGIS 10.3.1 (Managed Database of ArcGIS for Server on Server2)
Client (Windows 7 Enterprise)
  • Esri Maps for Office 3.1
  • Internet Explorer 11
  • Microsoft Office 2010
MarcoMedeiros
New Contributor II
Hi Nathan... Tks for helping.
I have seen at Esri support's link about it ( Working with Portal for ArcGIS—Esri Maps for Office | ArcGIS)  that I must to create a folder called 4.0. But in your link you are using 4.1. Is it can affect my setup?
NathanSmith8
New Contributor III
Marco,
This would depend on the version of ArcGIS Maps for Office that you installed. If you installed 4.0, create a folder named 4.0. If you installed 4.1, then you'll need to create a folder named 4.1 and ensure the resources are in that folder.
MarcoMedeiros
New Contributor II
I almost forgot... My Portal and my ArcGIS Server was installed on Linux (the same machine) and my Portal's link is: portal.sanepar.com/arcgis.
In this case i have to test my configuration using https://portal.sanepar.com/arcgis/resources/esrimapsforoffice/4.0/office/4.1.0.600/esriM4O/images/Fi... ?
BillFox
MVP Frequent Contributor
Does not like the portal's web adaptor in the url
It goes through with the :7443
BillFox
uninstalled maps for office, deleted remnant files on c:
re-installed maps for office, all good, even using web adaptor in url
