XML model [config.xml] is not configured properly
3073
03-16-2013 10:28 AM
TanaratMityodwong
New Contributor II
Hi everyone
Does anyone got problem like me? My problem is after I config a map in esri map designer and preview it.The warning "XML model [config.xml] is not configured properly" will appear and when go back to edit  a map in esri map designer, every thing that I just set is gone.
The error is [ATTACH=CONFIG]22667[/ATTACH]
Have ant Ideas?
Tanarat Mityodwong
Tags (3)
WaelYahya
Did you follow the steps in section 7.2 of the installation and configuration guide of ESRI IBM for cognos?
If yes , Can you send me the Fiddler or firebug log?
TanaratMityodwong
New Contributor II
wael yahya,
I already follow the steps in section 7.2 both of them (in the  installation and configuration guide has 2 section 7.2 Adding map service and Create default map).
I upload fiddler log at https://docs.google.com/file/d/0B0Q5f20uGuFTLVRyOW9GWC04ckE/edit?usp=sharing
My step is
- Open Esri map Designer
- Goto my report
- Click Configure
- Add esri street map 2D
- Set extent to USA
- Save & Close
- Click preview
- XML model [config.xml] is not configured properly appear
- Click ok and closd preview
- Click edit
- All setting is goto default and I add layer World street and set extent
- Click save & Close notthing happen so I click close(cross at top right)
please help me.
Tanarat M.
WaelYahya
TanaratMityodwong
New Contributor II
In the fiddler output , one line has an issue as follows:
http://cognosdemo.democentral.ibm.com/ibmcognos/vantage/cgi-bin/vantage.cgi?/vantage/ws/configInfo/V...
So, what I have to do next?
thanks,
Tanarat M.
TanaratMityodwong
New Contributor II
Finally, I can solve it. Just change Web server of IBM Cognos from Apache to IIS7 and set every thing follow installation and configuration guide. But,if I use Apache I still got error.
Tanarat M.
