I have created a mobile map service with uploads enabled. I have no errors in the ArcGIS server Manager Logs. Inside the water utility mobile map and inside the Mobile Poject Center I am unable to access the mobile service with the soap url getting the following error.
Error: Attempted to read or write protected memory. This is often an indication that other memory is corrupt.
I have a mobile map service running currently and the one I am publishing is simply that mxd with a few different layers. I am using the latest version of the Water Utility Mobile map and Mobile Project Center 10.2.0.0
Server Version
License level: | ArcGIS for Server Advanced |
Expiration Date: | Never |
Software version: | 10.2.1 (build 3497) |
screenshot from mobile project center below.
Any ideas?
Shane
