Unable to performapplyEdits operation during ArcPad and ArcGIS Server Syncronisation
3306
05-20-2014 04:26 AM
Kevin_RogersBwire
I am trying to upload my edits from arcpad to my arcgis for server
I get this 1 error during the process i.e.
Unable to perform applyEdits operation
RaymondHuang
Hi Kevin,
I think it will be helpful if you can share more information about the versions of ArcPad and Server that you are on.
Does this happen occasionally or it has never succeed in sending edits to ArcGIS for Server for this layer? I will suggest looking around the logs in ArcGIS for Server for more information during the period where you try to synchronize.
Raymond
Kevin_RogersBwire
Thanks Raymond
My Arcpad is 10.2
My ArcGIS Server is also 10.2
My Enterprise SQL DB is running ArcSDE geodatabase on 9.3.1 on a difference server.
ChristopherOlsen
Kevin,
I'm not sure if this is going to be possible with that data.  From my understanding, ArcPad 10.2 needs to use a feature service in order to edit.  This was introduced at 10.0, so I don't think your 9.3.1 data will work.
Chris
