Creating Output - Send Features to a Stream Service
1129
09-22-2016 07:34 AM
Dunn_Jeremy
New Contributor III
Good Afternoon,
I'm having a problem publishing a stream service when trying to send features to a stream service. I create the output but cannot publish it due to this error
The datastore used to perform this action does not have an associated token, and cannot perform the action anonymously. Edit the datastore properties to add a token, then try again
How can I correct this error ?
Regards.
Jeremy.
MarkBramer
Occasional Contributor II
Do you need to enter, or re-enter credentials for the data store connection in Manager-Site-Data Stores?
