Hi Everyone,
I'm having an issue with my GeoEvent environment post upgrade to 11.1 from 10.9.1 in which the default enterprise data store returns the following errors upon refresh:
LOGGER : com.esri.ges.datastore.agsconnection.DefaultArcGISServerConnection
Could not read content from ArcGIS Server: {0}. com.fasterxml.jackson.core.JsonParseException:
Unexpected character ('<' (code 60)): expected a valid value (JSON String, Number, Array, Object or token 'null', 'true' or 'false')
The admin connections page says the following about the default enterprise connection:
I have reset GeV configuration completely, without any configuration and have configured only the default connection to enterprise and I have tried:
Has anyone seen anything similar to this issue before?
## Edit 2023-09-07 : I forgot to mention that this issue occurs even when all data stores validate successfully, and imported existing geoevent services / inputs and outputs all work as expected also (I would usually only have the "Default" connection registered, but have connected individual servers to confirm they are accessible):
Poll an ArcGIS Server for Features:
An update to the admin page data store connections which is now logged as a bug:
