Thank you Adam! We have the ArcGIS server role and if i add the geoevent server role at the ArcGIS Enterprise level,should I able to install the Geoevent server on the new server machine?
Here is the scenario:
For example, ArcGIS Server is installed on "ABC" machine, and I wanted to install the geoevent server on "DEF" machine. How should I link these two inorder to proceed installing the geoevent server on "DEF" machine?
Thank you!
