Now that this is resolved at 10.4, can someone put me out of my misery and help explain how to allow logging into GeoEvent when I have a federated Portal which uses a DNS name?
- portal, server, web adaptor (IIS), data store & geoevent all on one machine on Azure
- Federated Server with Portal
- custom domain name, certificate exported and used in the root of IIS
- have updated the portal URL to use the domain name via the portal admin API
- Can login to Portal and ArcGIS Server fine using the domain name
- As GeoEvent does not go through IIS, I can hit it on its Azure URL, but get the invalid redirect URI error, as Portal does not trust someone trying to login from this foreign URL.
Im wondering how to get around this? Some kind of rewrite rule with ARR in IIS?
Larger context is I need to be allow access from the OSIsoft Pi Integrator for ArcGIS (which only works against a federated Portal) to login to GeoEvent.
UPDATE:
Just noticed that if I use CloudBuilder for Azure and choose self-signed, it creates a series of URL Rewrite rules in IIS under two subfolders
