GeoEvent Processor - Feed Parsing error: can't find the next feed
7796
7
07-31-2014 03:08 PM
KDeVogelaere
I'm getting an error "Feed Parsing error: can't find the next feed" when testing GeoEvent Processor with an RSS input using the USGS Earthquake URL, below is the full error log. Can someone help?
  1. com.esri.ges.manager.stream.internal.StreamBase
Restarting Stream 'rss-in-usgs-earthquakes' because the Transport is available again.
Thu Jul 31 16:02:03 CDT 2014
INFO
Stream (rss-in-usgs-earthquakes) has started successfully.
Thu Jul 31 16:06:58 CDT 2014
INFO
  1. com.esri.ges.processing.camel.CamelRouteBuilder
Camel route collection('rss-in-usgs-earthquakes') is being started...
INFO
  • org.apache.camel.blueprint.BlueprintCamelContext
Route: rss-in-usgs-earthquakes started and consuming from: Endpoint[jms://queue:rss-in-usgs-earthquakes]
INFO
SUCCESS!
INFO
  1. com.esri.ges.adapter.rss.RssInboundAdapter
ERROR
ClarkSherwin
We've figured it out. We had to set the proxy settings in 4 files. 3 of them are called "httpclient" Their locations and format are as follows
D:\Program Files\ArcGIS\Server\GeoEventProcessor\system\com\esri\ges\framework\httpclient\10.2.2
D:\Program Files\ArcGIS\Server\GeoEventProcessor\data\cache\bundle6\data\config\com\esri\ges
D:\Program Files\ArcGIS\Server\GeoEventProcessor\etc
And the fourth file is "net.properties" located D:\Program Files\ArcGIS\Server\GeoEventProcessor\jre\lib
And the final step was to set the input to not use a URL proxy
DonOpgenorth
I've
moved your post into the
Geoprocessing space. You will get a much better answer here as the GeoNet Help is intended for community help and feedback. I have also added in a few additional tags. You can see more
on the community structure, and what topics are under each space from the following documents:
GeoNet Community Structure
ArcGIS Discussion Forums Migration Strategy
Thanks!
Don
ClarkSherwin
MaartenTromp
I try to add login credentials to the proxy, so far unsuccessfully.
The error in the logging:
Internet input connector:
https://<internet URL>: Request failed(HTTP/1.1 407 authenticationrequired)
intranet input connector:
https://<intranet URL>: Request failed(HTTP/1.1 407 authenticationrequired)
For the intranet the proxy shoould NOT be used, for the internet the credentials should be used.
I tried to put the credentials and nonProxyHosts in the mentioned files like this:
httpclient.proxy.nonProxyHosts=*.<domain>.lan|10.*
httpclient.proxy.hostAndPort=proxy.<domain>.lan:8080
httpclient.proxy.proxyUser=<username>
httpclient.proxy.proxyPassword=<password>
The extra properties do not seem to be used.
How can I configure the nonProxyHost and the credentials?
Regards, Maarten Tromp
KDeVogelaere
Hi Maarten, have you tried adding the proxy with no login?  We are able to connect to both intranet and internet sites by adding the proxy address to the proxyHost value with no login.
MaartenTromp
without the login it indeed works fine. Luckily the IT department was willing to remove the required login for the specific server to get it to work.
Regards, Maarten
KDeVogelaere
Thanks Maarten, from what I have heard Proxy configurations are improved in the 10.3 GeoEvent release.  Here is the recommended steps from ESRI Support to setup access through a proxy for 10.2.2
1. On version 10.2.2, you need to navigate to geoevent processor Install directory:
2. Usually C:\Program Files\ArcGIS\Server\GeoEventProcessor
3. Go to etc\com.esri.ges.httpclient.cfg (Launch this file in notepad)
4. Add the proxy_host_name and port
#Set value to :
5.Save the edit and restart the GEP service
KDeVogelaere
In version 10.3.1, here are the steps for configuring proxy settings in GeoEvent
  • Login to GeoEvent
  • Go to Site
  • Settings
  • Then add proxy host and port settings for:
    • Http Proxy Host
    • Http Proxy Port
    • Https Proxy Host (optional)
    • Https Proxy Port (optional)
