GES 10.3.1 Vehicle Tracks
1661
02-16-2016 04:39 AM
MarkGoetz2
I'm attempting to draw Vehicle Incident tracks through an Incident Detector in 10.3.1 (Velocity > 5 (mph)).   Using a Create Feature output, lines are drawn, but for each Report the line is redrawn from the start of the incident to the current location resulting in too many overlapping features.   Using an Update Feature output, the lines are drawn as desired, but are obviously not persistent.   I've tried getting the Motion Detector processor installed but it won't load.   Any suggestions on how to get the results of the Update Feature and have the results persist?
MarkGoetz2
Figured it out.   Need to add a Filter after the Incident Detector to filter out the Incidents with a status of "Ended" only.   Figured it out by testing with JSON Output to fully understand what values are coming through based on Incident Definition.
MarkGoetz2
