Hi Guys,
I am trying perform similar functionality in 10.5.1
Input is (Poll an External Website for JSON), just pull all polygon from map service and grab all features by configuring as features in JSON object name.
And try to map into dummy geoevent definition which has object id and geometry only
And add polygon filter to geofence.
With this setup, from polygon map service there is no geofence polygon are intersected in geoevent.
But when I test by querying from that map service (used in input connector), a few geofence polygon (as input geometry) really intersect and get few features result.
And just breakdown and out put after field mapper, i got result in geoevent service but when I add this intersects filter, it is not working.
May I know is there something wrong with filter properties? or 10.5.1 does not support polygon filter yet?
Best Regards,
Than
