Using dates in filters?
2051
02-14-2017 10:51 PM
SimonJackson
Occasional Contributor III
I am listening to a public JSON feed for alerts.
Each result packet in the JSON includes forecast information.
I am only interested in the packet that matches todays date.
The data is in the format dd/mm/yyyyy and is a date type in the geoevent definition.
What is the most elegant way to filter this feed to just flow through todays date?
I did see this post to check if a date is within a given tolerance.  But hoping I can somehow achieve my goal purely with one filter?  Just not entirely sure if you can use date functions/expressions in a filter?
ThomasRickett
New Contributor III
I have version 10.7. I have the same question. How do I setup a date filter in GeoEvent Services?
wizgis
I am also facing the same issue. Any inputs would be appreciated.
