I am using the following environment:
ArcGIS for Server 10.2.1
SQL Server 2012
Windows Server 2012 R2
I am monitoring a folder for a new json file then processing it using the GeoEvent Processor (GEP).
It (the GEP) is successfully processing a file every five minutes (this is how often it is arriving from an external vendor).
I have the following issues:
Problem 1:
• The GEP doesnt delete the json files once they are processed. I have changed the setting in the 'input' to delete and also not delete but that does not do anything.
Problem 2:
• When you restart the GEP service it will reprocess any files in the directory even if they are old. It treats any json file as a new file.
NOTE: my json file has a .txt suffix but it is formatted json as per a specification supplied to the vendor.
NOTE: 03/10/2014: The GEP service was altered to use a file with a json suffix rather than a txt suffix. The issue is still happening.
Any help would be appreciated.
