AXIS IN THE ARCSCENE
970
09-28-2017 09:51 PM
AlesgerMammedov1
Good day.
I want to ask you, How can I add axis  X,Y,Z in the ArcScene
Do you have any idea for it, or where can I find script for it ?
JayantaPoddar
MVP Esteemed Contributor
Not sure of XYZ Axes shown across the layers in ArcScene.
But you could enable directional arrow navigation graphic.
Activating the directional arrow to help with navigation
Orient yourself in ArcScene using the directional arrow graphic.
1. Click View > View Settings and select the appropriate viewer.
2. Check the Directional Arrow box at the bottom of the window.
3. Click Cancel to close the View Settings dialog box.
The arrow now appears in the upper left of the 3D view. The larger, green arrow represents the y-direction in 3D space. If you are using a projected coordinate system then the green arrow will point north.
Think Location
AlesgerMammedov1
Good day
Thank you for your answer.
But i want to show labels of axes X,Y,Z  and line of axes X,Y,Z
Do you know how can do it ?
DanPatterson_Retired
I see no availability.  I think you are looking for something like what is available in MatPlotLib which you can access through python scripting
