Hi Mark, Thanks for the reply, your post prompted me to take a closer look and basically mine was exactly like yours.
Here is the before and after version (post a bit of fiddling)
"@type": "dcat:Catalog",
"conformsTo": "https://project-open-data.cio.gov/v1.1/schema",
"describedBy": "https://project-open-data.cio.gov/v1.1/schema/catalog.json",
"dataset": [
"@type": "dcat:Dataset",
"identifier": "http://opendata.arcgis.com/datasets/7e95eba45eb24855aa320c10e5c4b349_0",
"license": "http://opendata.arcgis.com/datasets/7e95eba45eb24855aa320c10e5c4b349_0/license.json",
"landingPage": "http://opendata.arcgis.com/datasets/7e95eba45eb24855aa320c10e5c4b349_0",
"title": "LOADME",
"description": "{{default.description}}",
"keyword": [
"DCAT_TEST"
"@context": "https://project-open-data.cio.gov/v1.1/schema/catalog.jsonld",
"dataset": [
"license": "https://creativecommons.org/licenses/by/4.0/",
"title": "LOADME",
"keyword": [
"DCAT_TEST"
"issued": "2020-05-29T10:25:21.000Z",
So I now know I can change the content of the DCAT and for this particular example I just hard coded it with a url as for the moment but I also got it working with the dcat elements that popup on the righthand side when your editing (excuse the terminology I couldn't find and help or direction on this)
I just added one line into the DCAT configuration (bold below) but it can be dynamic using the metadata item
"title": "{{default.name}}",
"keyword": "{{item.tags}}",
"issued": "{{item.created:toISO}}",
"modified": "{{item.modified:toISO}}",
"publisher": {
"source": "{{default.source.source}}"
"contactPoint": {
"hasEmail": "{{metadata.metadata.mdContact.rpCntInfo.cntAddress.eMailAdd}}",
"mbox": "info@gsi.ie"
So for the moment it works ... I just have to better understand the whole configuration aspect. Thanks for the post
Paulg
