How to prevent info/side bar from appearing - Dashboard
1035
07-06-2022 01:52 AM
Lindsay
Hi there,
I've added in a dashboard as an application into a page. Whenever I go to published mode, a sidebar with stats about it appears. I don't want to see this. It is also appearing for another admin because we are content managers. We don't want to see this though. Is there anyway to prevent this from happening? I also notice as soon as I added the dashboard in, the menu in the header disappeared. Is this related? The only way to get back to the other parts of the Hub now are through the logo, which is the home. On all the other pages, the header/menu remains.
Thanks in advance for your help.
DataOfficer
In your hub site go to Settings -> Interactions -> Content Side Panel
Set the side panel to 'collapsed' for anything you don't want the sidebar to appear for.
Example:
More info here: https://doc.arcgis.com/en/hub/sites/configure-site-settings.htm#ESRI_SECTION1_0E9EEF9080BA4EB39C04F8...
DataOfficer
Example:
Laura
by MVP Regular Contributor
Do you know if this can be done with EXB?
Lindsay
Thanks @DataOfficer !
