Map widget option missing in Open Data portal
3250
07-07-2015 01:37 AM
SimonLutman
New Contributor II
In the Design Layout tab of the ArcGIS Open Data portal, I can use the wizard to add a widget to the Body Content section, but cannot select the map widget option from the dropdown Content Type. The options available are 'Text', 'Image', 'RSS Feed' and 'Data Listing' (see screenshot below). The workaround is to switch from 'Wizard' to 'Code'. Any suggestions?
Tags (3)
CourtneyClaessens
Occasional Contributor III
Hi Simon,
We deprecated the dataset map widget from the layout editor a little ways back - it had some issues. Were you using it successfully before?
Courtney
SimonLutman
New Contributor II
Hi Courtney, thanks for your reply.
I was, it was never a problem. I have now reverted to using the coding method.
York's ArcGIS Open Data portal
Simon
PS any chance of fixing the 'save' button that dropped off the Design Layout (see previous post)
CourtneyClaessens
Which post are you referring to?
SimonLutman
New Contributor II
