Mega Menu Support???
526
11-06-2019 08:19 AM
EricShreve
Occasional Contributor II
Does anyone know if ArcGIS Hub supports Mega Menu capabilities? I took a screenshot of an example that I would like to have that was done in Drupal with our emergency bulletin site.
KlaraSchmitt
Hello Eric,
Out-of-the-box our header and menu selection options do not support mega menus. If you choose the custom header, you may be able to create your own using all CSS. However, we don't have any examples of customers who've done this readily available for reference. I'd recommend searching for Bootstrap 3 mega menu examples and experimenting off those to build a custom header for your site.
-Klara
KlaraSchmitt
Hello Eric,
-Klara
EricShreve
Klara Schmitt‌ thank you for the clarification. Theoretically you should be able to do this all within the text card to apply the CSS?
KlaraSchmitt
Hi Eric,
Not quite the text card. You can do custom embedded styles within the text card if you want to style other elements of the homepage or stand alone pages, but if you want the mega menu in your Header, you'll want to open Header from the Customize Pane in the Site Editor and choose the Custom HTML/CSS radio from the Appearance accordion. Once you've selected that, you can put your custom header Bootstrap in the HTML block and put the CSS you're using to control the mega menu in the CSS block. The HTML and CSS blocks for the Header will remain scoped to the Header, so you it'll only affect that component.
