We have a map services that are in ArcGIS Online but are not being shown in the data section of ArcGIS Hub.
Everything is set correctly. The map services are shared with our Open Data Group.
Most of our services are shown in the data section of ArcGIS Hub and these services used to appear but don't now. Has something happened to ArcGIS Hub?
I have attached to pictures to illustrate. 1st is the ArcGIS Online item. 2nd is that only the UK Boundaries are shown in ArcGIS Hub when searching for 2017 Ward Boundaries and the 3rd shows no items when searching for the 2017 Ward Boundaries in Great Britain.
I have tried to
Update the index which has no effect.
I have also unshared and shared the item in ArcGIS Online, with no effect.
I have edited the item in ArcGIS Online and saved it so that the update date changes. Again no effect.
Is there anything else that can be done?
Is this a known issue?
Matt
