White space around Header on Arcgis hub
724
6
11-08-2023 10:13 AM
GD2
Hi everybody, I am having the issue of white space above the Header. Header is customized as below:- any suggestion is highly appreciated :-
<nav class="navbar navbar-default navbar-static-top first-tier">
<div class="container">
<ul style="padding: 30px 0 0 0;" class="nav nav-pills pull-right" role="navigation">
<li><a href="https://" "/search?collection=Dataset">Data</a></li>
<li><a href="https://" "/search?tags=Pdf">Documents</a></li>
<li><a href="https://" "/MapAndAppGallery/index.html?appid=7b9a21a3e33e45a3abcf6ebc694aa...">Map & Apps</a></li>
</ul>
<div class="navbar-brand">
<div class="site-logo">
<img src="https://" "/content/items/28daf41d36b84a9a93d567f9267665ea/data" alt="">
</div>
</div>
</div>
</nav>
2 Solutions
dgiersz_cuyahoga
That white space with the search icon?  That's the Global Navigation bar.  Turn it off under Site>Settings>Interactions
#CLE #sloth
dgiersz_cuyahoga
A couple things: the <div>'s you set to not display are empty.  Also, you can assign multiple classes to a tag. And finally, I think the .hidden classes are to hide things instead of setting the .visible to not display.
I am not a bootstrap or HTML expert, but give this a try:
<li><a href="https://data-airdrie.opendata.arcgis.com/search?collection=Dataset">Data</a></li>
<li><a href="https://data-airdrie.opendata.arcgis.com/search?tags=Pdf">Documents</a></li>
<li><a href="https://airdrie.maps.arcgis.com/apps/MapAndAppGallery/index.html?appid=7b9a21a3e33e45a3abcf6ebc694aa...">Map & Apps</a></li>
</ul>
<div class="site-logo hidden-xs hidden-sm">
<img src="https://airdrie.maps.arcgis.com/sharing/rest/content/items/28daf41d36b84a9a93d567f9267665ea/data" alt="" >
</div>
</div>
</div>
</nav>
#CLE #sloth
dgiersz_cuyahoga
#CLE #sloth
GD2
@dgiersz_cuyahoga Awesome, that worked perfectly, thanks alot. I am now having the issue with Mobile view on my header as well as footer. They are overlapping with each other. Please see the attached image. Any idea to solve this?
dgiersz_cuyahoga
You can try adding classes to the "site-logo" to hide it on small screens.
Options based on screen size:
https://getbootstrap.com/docs/3.4/css/#responsive-utilities
#CLE #sloth
GD2
@dgiersz_cuyahoga  Thank you again. I added new classes (with style as display: none) as follows but with no luck. I am very new with Bootstrap in html, could you please point out where and what am I missing to remove the logo on mobile view? Thank you so much!
<li><a href="https://search?collection=Dataset">Data</a></li>
<li><a href="https://search?tags=Pdf">Documents</a></li>
<li><a href="https:///apps/MapAndAppGallery/index.html?appid=7b9a21a3e33e45a3abcf6ebc694aabea">Map & Apps</a></li>
</ul>
<div style="display:none;" class=".visible-md-*">
</div>
<div style="display:none;" class=".visible-sm-*">
</div>
<img src="https:///28daf41d36b84a9a93d567f9267665ea/data" alt="">
</div>
</div>
</div>
</nav>
dgiersz_cuyahoga
</ul>
</div>
</div>
</div>
</nav>
#CLE #sloth
GD2
@dgiersz_cuyahoga This worked perfectly. Thank you so much for your comments and an additional class. Very much appreciated !
