<Message>Command:sentinelModifySrc->User defined command (sentinelModifySrc)</Message>
<Message>Adding Field to MasterTiles...</Message>
<Message>adding to the feature class for interverl 2023-07-01/2023-07-31...</Message>
<Message>adding to the feature class S2A_13SDB_20230730_0_L2A...</Message>
<Message>adding to the feature class S2A_13SDC_20230730_0_L2A...</Message>
<Message>adding to the feature class S2B_13SCA_20230725_0_L2A...</Message>
<Message>adding to the feature class S2B_13SDA_20230725_0_L2A...</Message>
<Message>adding to the feature class S2B_13SCB_20230725_0_L2A...</Message>
<Message>adding to the feature class S2B_13SDB_20230725_0_L2A...</Message>
<Message>adding to the feature class S2B_13SDC_20230725_0_L2A...</Message>
<Message>adding to the feature class S2B_13SCA_20230722_0_L2A...</Message>
<Message>adding to the feature class S2B_13SDA_20230722_0_L2A...</Message>
<Message>adding to the feature class S2B_13SCB_20230722_0_L2A...</Message>
<Message>adding to the feature class S2B_13SDB_20230722_0_L2A...</Message>
<Message>adding to the feature class S2A_13SCA_20230720_0_L2A...</Message>
<Message>adding to the feature class S2A_13SDA_20230720_0_L2A...</Message>
<Message>adding to the feature class S2A_13SDB_20230720_0_L2A...</Message>
<Message>adding to the feature class S2A_13SCA_20230717_0_L2A...</Message>
<Message>adding to the feature class S2A_13SDA_20230717_0_L2A...</Message>
<Message>adding to the feature class S2A_13SCB_20230717_0_L2A...</Message>
<Message>adding to the feature class S2A_13SDB_20230717_0_L2A...</Message>
<Message>adding to the feature class S2A_13SDC_20230717_0_L2A...</Message>
<Message>adding to the feature class S2B_13SCA_20230715_0_L2A...</Message>
<Message>adding to the feature class S2B_13SDA_20230715_0_L2A...</Message>
<Message>adding to the feature class S2B_13SCB_20230715_0_L2A...</Message>
<Message>adding to the feature class S2B_13SDB_20230715_0_L2A...</Message>
<Message>adding to the feature class S2B_13SCC_20230715_0_L2A...</Message>
<Message>adding to the feature class S2B_13SDC_20230715_0_L2A...</Message>
<Message>adding to the feature class S2B_13SCA_20230712_0_L2A...</Message>
<Message>adding to the feature class S2B_13SCB_20230712_0_L2A...</Message>
<Message>adding to the feature class S2B_13SDB_20230712_0_L2A...</Message>
<Message>adding to the feature class S2A_13SCB_20230707_0_L2A...</Message>
<Message>adding to the feature class S2A_13SDB_20230707_0_L2A...</Message>
<Message>adding to the feature class S2A_13SDC_20230707_0_L2A...</Message>
<Message>adding to the feature class S2B_13SCA_20230705_0_L2A...</Message>
<Message>adding to the feature class S2B_13SDA_20230705_0_L2A...</Message>
<Message>adding to the feature class S2B_13SCB_20230705_0_L2A...</Message>
<Message>adding to the feature class S2B_13SDB_20230705_0_L2A...</Message>
<Message>adding to the feature class S2B_13SCC_20230705_0_L2A...</Message>
<Message>Adding Field to BandTiles...</Message>
<Message>Calculating the Q and Best value...</Message>
<Message>adding band feature class ...</Message>
<Status>OK</Status>
<Duration>10</Duration>
