Hello everyone,
I am using a pretrained model for building detection on ArcGIS 3.0.0 Pro, when I set the processor type as CPU it works perfectly, but I want to use the GPU which is throwing these errors:
My GPU is Nvidia GeForce RTX 2070 Super. I checked if torch.cuda.is_available() returns true or not and it returned True.
Please help me in this.
Thank you in advance,
Can you share the name of the pre-trained model? Are you using a local raster (e.g tif , jpg) or using image service or webgis layer as an input raster?
regards
Pavan
Hello Pavan,
Thank you for your response. The name of the pre-trained model is: Building Footprint Extraction - KSA.
Please find it through the following link: https://esrisaudi-ai.maps.arcgis.com/home/item.html?id=63785ee9860d4bd68cd82caccdcf1742
I'm using the world imagery service layer.
Mayar
@MayarAlzerkiI am sorry, I missed your last comment. When you use the World Imagery basemap layer, you need to define an extent (try a small one in the environment tab) and a cell size (something between 0.1 and 0.5). I agree, the error message was wrong. However, my understanding is that there are some licensing limitations on how you can use the World Imagery basemap as an input.
@VinayViswambharan can you comment on the usages of the world imagery for AI inferencing?
thanks
Pavan
Hello @PavanYadav,
It's fine no worries, actually, I'm not working on it anymore, but on my free time I would give it a try for sure!
Appreciate your response. Thank you!
Hi @MayarAlzerki - The world imagery cannot be used for inferencing or programmatic access. It is violating the terms of use of the basemap (which is designed currently to be used only as a basemap).
Regards,
Vinay
Hello @VinayViswambharan1!
Apologiess, I think that I did not get your point. Do you mean that it's not allowed in GPU only? Because I can do detection using my CPU
