I've an established survey that uses Coded Domains within the feature layer and relationship table. I'm wanting to calculate out expressions to give costs etc. that look directly at the coded values.
For example, cost evaluations;
A routine survey costs £xx.xx , I want the expression to look for all Routine Surveys in a coded field and calculate the value.
Within Insights I can't see any attribute columns that are coded domains. This does differ from Dashboards where you can filter and express a value.
Long question, cut short - Is there a work around for coded domains in Insights?
