Coded Domains Fields and Values in Insight
704
01-06-2021 07:56 AM
JonathanMcDougall
I've an established survey that uses Coded Domains within the feature layer and relationship table. I'm wanting to calculate out expressions to give costs etc. that look directly at the coded values.
For example, cost evaluations;
A routine survey costs £xx.xx , I want the expression to look for all Routine Surveys in a coded field and calculate the value.
Within Insights I can't see any attribute columns that are coded domains. This does differ from Dashboards where you can filter and express a value.
Long question, cut short - Is there a work around for coded domains in Insights?
ScottSandusky
Hi Jonathan,
Starting at Insights version 2020.1, we added support for domains and subtypes. Do you know what version of Insights you are using?
https://doc.arcgis.com/en/insights/2020.1/get-started/whats-new.htm
ScottSandusky
Hi Jonathan,
JonathanMcDougall
Yes, 2020.3 and AGOL Insights.
So, I realise that within a table I can view the coded domain fields, however, applying advanced filters or calculating a field based upon a domain result, as per my post, doesn't seem to be possible. Just looking for any work around - I'm looking to support a team manage contract costs based upon inspection types (a domain field) x a fixed cost.
