Hi @KellyHutchins
Can you test if your layer search Suggestions work as a "Contains"? I can only get my layer search to return results if I search the start of the string.
Example below, "Mission Bay" will return a bunch of results but we're wanting users to be able to type in "Fanuel" or "Crown Point" and have it suggest those results.
I have verified it is set to "Contains" in the map item settings:
Thank you!
of note, my layer is hosted in Enterprise 10.8.1 and shared publicly.
