I am using the fieldInfos to set the content in a popup. At 4.3, I could put html in the label property to take advantage of the title attribute that would show a description of the field when the user hovered. At 4.4, the html is not converted to text.
fieldInfos: [{
fieldName: "SufficiencyRating",
visible: true,
label: "<span title='An indication of the bridge’s capacity to remain in service (0 -100)'>Sufficiency Rating</span>"
at 4.3:
(not sure why the screen shot has transparency on the tooltip, please ignore)
at 4.4:
Here are a couple JSBins to show the problem:
4.3: JS Bin - Collaborative JavaScript Debugging
4.4: JS Bin - Collaborative JavaScript Debugging
Is this a bug? Is there another way to accomplish this?
