add layer values to legend
738
07-26-2017 02:35 AM
FaryalSafdar
i have created a legend.
var legend = new Legend({      map: map,      layerInfos: [        {          layer: S_layer,          title: "Factors"        }       ]    }, "legendDiv");     legend.startup();
now i want to add another attribute of the same layer into the legend. i have seen examples of adding another layer to the legend . but could not find any example of how to add attributes of same layer to the legend. can anyone tell me how to solve this problem?
EvelynHernandez
Occasional Contributor III
I still dont understand what u wanna do, but this example may help u.
In the service they setted up a feature layer with 5 different symbol types and they made just one legend that containts the layers that have been added in the map.
ArcGIS API for JavaScript Sandbox
FaryalSafdar
thanks for your response. but this example has two different layer. my problem is, i have to display different attributes of
same layer in the legend. for example in the pictureit shows only one factor i want to add another factor like temp of the same layer in this legend
EvelynHernandez
Im not sure if u can do that programatically, so why u dont use arcmap for having a layer with multiple factors?.
Most of the time u need to use more than 1 layer to represent different kind of things, for example temperature and wind Also , maybe u will need to have a dynamic layer for showing more than 1 factor at the time in the legend, in that way u can have 2 or more layers in the same service.
FaryalSafdar
but if we have 2 or more layer in the same service like r_soil layer, r_temp layer etc. is it appropirate way to do it? because i have to create a gdb of soil map and temp layer of many cities. and it shows on the map by user demand
FaryalSafdar
sir if we add another forexample temperature. then can we extract particular temp i.e of one city. and display in the legend?
