Robert
Thanks for the solution! I have a problem though when I add it to my Calcite Maps template. I get TypeError: Cannot read property 'create' of undefined on the first domConstruct.create for the addtoSelect. Then TypeError for the dojo on() watching for "changes". I cannot seem to nail down where dojo is failing. Is calcite using an older version of dojo? I think I have all the modules loaded correctly.
<!DOCTYPE html>
<html>
<head>
<meta charset="utf-8">
<meta name="viewport" content="width=device-width,initial-scale=1,maximum-scale=1,user-scalable=no">
<meta name="description" content="ArcGIS JS v4, Calcite Maps and Bootstrap Example">
<title>Utah Plant Portal</title>
<!-- Calcite Maps Bootstrap -->
<link rel="stylesheet" href="https://esri.github.io/calcite-maps/dist/css/calcite-maps-bootstrap.min-v0.9.css">
<!--link rel="stylesheet" href="http://localhost/GitHub/calcite-maps/dist/css/calcite-maps-bootstrap.min-v0.9.css"-->
<!-- Calcite Maps -->
<link rel="stylesheet" href="https://esri.github.io/calcite-maps/dist/css/calcite-maps-arcgis-4.x.min-v0.9.css">
<!--link rel="stylesheet" href="http://localhost/GitHub/calcite-maps/dist/css/calcite-maps-arcgis-4.x.min-v0.9.css"-->
<!-- ArcGIS JS 4 -->
<link rel="stylesheet" href="https://js.arcgis.com/4.9/esri/css/main.css">
<style>
html,
body {
margin: 0;
padding: 0;
height: 100%;
width: 100%;
.dds {
top: 295px;
left: 15px;
position: absolute;
display: inline-block;
</style>
</head>
<body class="calcite-maps calcite-nav-top">
<!-- Navbar -->
<nav class="navbar calcite-navbar navbar-fixed-top calcite-text-light calcite-bg-dark">
<!-- Menu -->
<div class="dropdown calcite-dropdown calcite-text-dark calcite-bg-light" role="presentation">
<a class="dropdown-toggle" role="menubutton" aria-haspopup="true" aria-expanded="false" tabindex="0">
<div class="calcite-dropdown-toggle">
<span class="sr-only">Toggle dropdown menu</span>
<span></span>
<span></span>
<span></span>
<span></span>
</div>
</a>
<ul class="dropdown-menu" role="menu">
<li><a role="menuitem" tabindex="0" data-target="#panelInfo" aria-haspopup="true"><span class="glyphicon glyphicon-info-sign"></span> About</a></li>
<li><a role="menuitem" tabindex="0" href="#" data-target="#panelBasemaps" aria-haspopup="true"><span class="esri-icon-basemap"></span> Basemaps</a></li>
<li><a role="menuitem" tabindex="0" href="#" data-target="#panelLegend" aria-haspopup="true"><span class="glyphicon glyphicon-list-alt"></span> Legend</a></li>
<li><a role="menuitem" tabindex="0" href="#" id="calciteToggleNavbar" aria-haspopup="true"><span class="glyphicon glyphicon-fullscreen"></span> Full Map</a></li>
</ul>
</div>
<!-- Title -->
<div class="calcite-title calcite-overflow-hidden">
<span class="calcite-title-main">Utah Geological Survey</span>
<span class="calcite-title-divider hidden-xs"></span>
<span class="calcite-title-sub hidden-xs">Plant Portal</span>
</div>
<!-- Nav -->
<ul class="nav navbar-nav calcite-nav">
<li>
<div class="calcite-navbar-search calcite-search-expander">
<div id="searchWidgetDiv"></div>
</div>
</li>
</ul>
</nav>
<!--/.calcite-navbar -->
<!-- Map -->
<div class="calcite-map calcite-map-absolute">
<div id="mapViewDiv"></div>
</div>
<!-- /.calcite-map -->
<div class="dds">
<select id="waterShed"></select>
</div>
<!-- Panels -->
<div class="calcite-panels calcite-panels-right calcite-text-light calcite-bg-dark panel-group">
<!-- Panel - Info -->
<div id="panelInfo" class="panel collapse in">
<div id="headingInfo" class="panel-heading" role="tab">
<div class="panel-title">
<a class="panel-toggle" role="button" data-toggle="collapse" href="#collapseInfo" aria-expanded="true" aria-controls="collapseInfo"><span class="glyphicon glyphicon-info-sign" aria-hidden="true"></span><span class="panel-label">About</span></a>
<a class="panel-close" role="button" data-toggle="collapse" tabindex="0" href="#panelInfo"><span class="esri-icon esri-icon-close" aria-hidden="true"></span></a>
</div>
</div>
<div id="collapseInfo" class="panel-collapse collapse in" role="tabpanel" aria-labelledby="headingInfo">
<div class="panel-body">
<p>This is my map app!</p>
</div>
</div>
</div>
<!-- Basemaps Panel -->
<div id="panelBasemaps" class="panel collapse">
<div id="headingBasemaps" class="panel-heading" role="tab">
<a class="panel-toggle collapsed" role="button" data-toggle="collapse" href="#collapseBasemaps" aria-expanded="false" aria-controls="collapseBasemaps"><span class="glyphicon glyphicon-th-large" aria-hidden="true"></span><span class="panel-label">Basemaps</span></a>
<a class="panel-close" role="button" data-toggle="collapse" data-target="#panelBasemaps"><span class="esri-icon esri-icon-close" aria-hidden="true"></span></a>
</div>
</div>
<div id="collapseBasemaps" class="panel-collapse collapse" role="tabpanel" aria-labelledby="headingBasemaps">
<select id="selectBasemapPanel" class="form-control">
<option value="streets" data-vector="streets-vector">Streets</option>
<option value="satellite" data-vector="satellite" selected="">Satellite</option>
<option value="hybrid" data-vector="hybrid">Hybrid</option>
<option value="national-geographic" data-vector="national-geographic">National Geographic</option>
<option value="topo" data-vector="topo-vector">Topographic</option>
<option value="gray" data-vector="gray-vector">Gray</option>
<option value="dark-gray" data-vector="dark-gray-vector">Dark Gray</option>
<option value="osm" data-vector="osm">Open Street Map</option>
<option value="dark-gray" data-vector="streets-night-vector">Streets Night</option>
<option value="streets" data-vector="streets-navigation-vector">Streets Mobile</option>
</select>
</div>
</div>
</div>
<!-- Panel - Legend -->
<div id="panelLegend" class="panel collapse">
<div id="headingLegend" class="panel-heading" role="tab">
<a class="panel-toggle" role="button" data-toggle="collapse" href="#collapseLegend" aria-expanded="false" aria-controls="collapseLegend"><span class="glyphicon glyphicon-list-alt" aria-hidden="true"></span><span class="panel-label">Legend</span></a>
<a class="panel-close" role="button" data-toggle="collapse" tabindex="0" href="#panelLegend"><span class="esri-icon esri-icon-close" aria-hidden="true"></span></a>
</div>
</div>
<div id="collapseLegend" class="panel-collapse collapse" role="tabpanel" aria-labelledby="headingLegend">
<div id="legendDiv"></div>
</div>
</div>
</div>
</div>
<!-- /.calcite-panels -->
<script type="text/javascript">
var dojoConfig = {
packages: [{
location: "https://esri.github.io/calcite-maps/dist/vendor/dojo-bootstrap"
location: "https://esri.github.io/calcite-maps/dist/js/dojo"
</script>
<script src="https://js.arcgis.com/4.9/"></script>
<script>
require([
"esri/Map",
"esri/views/SceneView",
"esri/layers/FeatureLayer",
"esri/tasks/support/Query",
"esri/widgets/Home",
"esri/widgets/Zoom",
"esri/widgets/Compass",
"esri/widgets/Search",
"esri/widgets/Legend",
"esri/widgets/BasemapToggle",
"bootstrap/Collapse",
"bootstrap/Dropdown",
"calcite-maps/calcitemaps-v0.9",
"calcite-maps/calcitemaps-arcgis-support-v0.9",
"dojo/on",
"dojo/dom",
"dojo/dom-construct",
"dojo/domReady!"
], function(Map, SceneView, FeatureLayer, Query, Home, Zoom, Compass, Search, Legend, BasemapToggle, ScaleBar, Attribution,Collapse, Dropdown, CalciteMaps, CalciteMapArcGISSupport, on, dom, domConstruct) {
var pointSymbol = {
type: "simple-marker",
color: "cyan",
outline: {
color: "black",
width: 0.3
var renderSite = {
type: "simple",
symbol: pointSymbol,
var plantSites = new FeatureLayer({
url: "https://services.arcgis.com/ZzrwjTRez6FJiOq4/ArcGIS/rest/services/plantPortalTestV2_View/FeatureServ...",
title: "Plant Sites",
visibile: true,
outFields: ["huc8", "wetlandType"],
elevationInfo: [{
mode: "on-the-ground"
renderer: renderSite
var map = new Map({
basemap: "hybrid",
layers: [plantSites],
ground: "world-elevation",
var mapView = new SceneView({
container: "mapViewDiv",
map: map,
center: [-112, 40.7],
zoom: 11,
padding: {
top: 50,
bottom: 0
ui: {components: []}
mapView.when(function(){
CalciteMapArcGISSupport.setPopupPanelSync(mapView);
var searchWidget = new Search({
container: "searchWidgetDiv",
view: mapView
var home = new Home({
view: mapView
mapView.ui.add(home, "top-left");
var zoom = new Zoom({
view: mapView
mapView.ui.add(zoom, "top-left");
var compass = new Compass({
view: mapView
mapView.ui.add(compass, "top-left");
var basemapToggle = new BasemapToggle({
view: mapView,
secondBasemap: "satellite"
var legendWidget = new Legend({
container: "legendDiv",
view: mapView
var waterShedSelect = document.getElementById("waterShed");
mapView.when(function() {
console.log("querying");
return plantSites.when(function() {
var watershedQuery = new Query();
watershedQuery.where = "1=1";
watershedQuery.outFields = ["huc8"];
watershedQuery.returnDistinctValues = true;
watershedQuery.orderByFields = ["huc8"];
return plantSites.queryFeatures(watershedQuery);
}).then(addToSelect)
.otherwise(queryError);
function queryError(error) {
console.error(error);
function addToSelect(values) {
console.log("adding to select");
var option = domConstruct.create("option");
option.text = "";
waterShedSelect.add(option);
values.features.forEach(function(value) {
option.text = value.attributes.huc8;
function setDefinitionExpression() {
var strregion = waterShedSelect.options[waterShedSelect.selectedIndex].value;
if (strregion) {
plantSites.definitionExpression = "huc8 = '" + strregion + "'";
} else if (strregion != "") {
if (!plantSites.visible) {
plantSites.visible = true;
on(waterShedSelect, "change", function(evt) {
var type = evt.target.value;
setDefinitionExpression();
</script>
</body>
</html>
