I'm performing a MapView.hitTest() against a feature layer in a webmap and running across inconsistencies with attributes being returned. I get a reference to the feature layer and set the outFields I want returned. However, sometimes the graphic that is 'hit' only returns the ObjectId. Other times it returns all attributes specified in outFields.
view.on("click", function (event) {
view.hitTest(event).then(function (response) {
if (response.results.length) {
var graphic = response.results.filter(function (result) {
return result.graphic.layer === myLayer;
})[0].graphic;
// graphic.attributes only contains objectid
// OR
// graphic.attributes contains objectid, att1, att2, att3, etc...
What is the expected behavior? For instance, should you assume that you may only get back an ObjectId and not additional attributes set through FeatureLayer.outFields? Does hitTest ignore outFields?
