can i get the map width at a particular scale without actually zooming the map to that scale
1302
03-15-2017 05:09 AM
DeepikaJain1
Hi
I am using ArcGIS JavaScript API 4.2 and need to get the width of the map at multiple scales on load without actually zoomin the map to that scale.
thejuskambi
If you are using, cached map service. Then you could use the LOD.resolution to calculate the width of the map. Just multiple it with the pixel width of the map and you will get the map extent width.
RobertScheitlin__GISP
Deepika,
  Unfortunately scaleUtils is marked as Coming Soon.
Functionality matrix | ArcGIS API for JavaScript 4.3
thejuskambi
DeepikaJain1
Thanks for the solution, it worked like a charm!
