Change BasemapGallery thumbnail size
3526
10
02-19-2016 10:13 AM
AustinMulder
I am looking for a way to change the size of the thumbnails within the basemapGallery.  I have thumbnails that are 300x200px but the gallery seems to have a default size of around 60x50px which it forces all thumbnails to.  i would like to increase the size of these thumbnails but cannot find a single example of how to do this, or any reference anywhere regarding thumbnail size.
Any ideas?
KenBuja
In the CSS, you can make changes to the .esriBasemapGalleryThumbnail size.
.esriBasemapGalleryThumbnail {
      height: 100px;
      width: 150px;
However, just modifying this throws off the spacing of the thumbnails, so you'll have to explore the other settings
AdrianWelsh
MVP Honored Contributor
I do not think that you can change the size of these thumbnails in Esri's out-of-the-box galleries. You will likely have to custom create your own landing page to make a gallery of maps/apps in order to make the thumbnails different. Though, I could be wrong...
RickeyFight
MVP Regular Contributor
Austin,
Can you post the code you are working with or a sample you are basing your wepapp off of ?
KenBuja
      height: 100px;
      width: 150px;
KenBuja
Changing .esriBasemapGalleryNode fixes the overlap problem
.esriBasemapGalleryNode {
  width: 150px;
AustinMulder
Thanks for the quick answer Ken,
Unfortunately I am not seeing any change.  I am using JavaScript 3.15 if that matters..
here is the site I am working on: NeoTreks Maps - Recreation and Trail Maps for the Untied States
ChrisSmith7
Austin,
I tried it on my end and it appears to work - are you sure your browser isn't caching something?
KenBuja
But you didn't make any changes in the CSS values in your code.
By the way...why are you still using legacy style coding (dojo.require)?
AustinMulder
faceplam...yes, it is now working.
As to the dojo.require, what would be the appropriate way to do it now?
ChrisSmith7
Esri require - check out a sample:
Basemap gallery | ArcGIS API for JavaScript
require([
      "esri/map", "esri/dijit/BasemapGallery", "esri/arcgis/utils",
      "dojo/parser",
      "dijit/layout/BorderContainer", "dijit/layout/ContentPane", "dijit/TitlePane",
      "dojo/domReady!"
    ], function(
      Map, BasemapGallery, arcgisUtils,
      parser
Just make sure the module order is the same! Here's some more info:
Working with Dojo | Guide | ArcGIS API for JavaScript
Note, in the example code, there were some modules not passed in the function - they were referenced in the front-end instead of in the script block.
