checkbox are not working in toc
2450
02-04-2016 11:11 PM
veenahosur1
New Contributor II
i have toc for dynamic and feature layers.its displaying properly but when i checked on and off checkbox nothing is chaning on layers
below is code:
    <!DOCTYPE html>
    <html>
    <head>
        <title>Create a Map</title>
        <meta http-equiv="content-type" content="text/html; charset=utf-8">
        <meta name="viewport" content="initial-scale=1,maximum-scale=1, user-scalable=no">
        <link rel="stylesheet" href="http://js.arcgis.com/3.11/dijit/themes/soria/soria.css">
        <link rel="stylesheet" href="http://js.arcgis.com/3.11/esri/css/esri.css">
        <!--<link href="agsjs/dijit/css/TOC.css" rel="stylesheet" type="text/css" />-->
        <link rel="stylesheet" type="text/css" href="http://gmaps-utility-gis.googlecode.com/svn/tags/agsjs/latest/build/agsjs/css/agsjs.css" />
        <style>
            html, body, #mapDiv {
                padding: 0;
                margin: 0;
                height: 100%;
                width: 100%;
                overflow: hidden;
            #tocDiv {
                z-index: 50;
                position: absolute;
                top: 0%;
                left: 0%;
                width: 300px;
                height: auto;
                background-color: White;
            #divDialogProcess {
                z-index: 50;
                position: absolute;
                right: 0%;
                top: 0%;
        </style>
        <script>
            var dojoConfig = {
                packages: [{
                    "location": '/2.10/build/agsjs' // for xdomain load
        </script>
        <script src="http://js.arcgis.com/3.11/"></script>
        <script>
            var map, tiled, pointFeatureLayer, operationalLayer;
            require(["dojo/_base/connect",
  "esri/map", "esri/config",
                     "esri/geometry/Extent",
                     "esri/layers/ArcGISDynamicMapServiceLayer",
                     "esri/layers/FeatureLayer",
                     "esri/renderers/ClassBreaksRenderer",
                     "esri/symbols/SimpleFillSymbol",
                     "esri/tasks/GeometryService",
                     "dojo/dom",
                     "dojo/dom-geometry",
                     "dojo/fx",
                     "dojo/on",
                     "dojo/parser",
                     "dojo/_base/Color",
                     "agsjs/dijit/TOC",
                     "dijit/layout/BorderContainer",
          "dijit/layout/ContentPane",
                     "dojo/domReady!"], function (connect,Map, esriConfig, Extent, ArcGISDynamicMapServiceLayer, FeatureLayer, ClassBreaksRenderer, SimpleFillSymbol, GeometryService, dom, domGeom, coreFx, on, parser, Color, TOC
                    map = new Map("mapDiv", {
                     center: [77.2, 14],
                     zoom: 7,
                     basemap: "topo",
                     slider: false
                         operationalLayer = new ArcGISDynamicMapServiceLayer("http://164.100.133.131/arcgisserver/rest/services/CRD/CRD1/MapServer", { id: "Operational", opacity: 0.5 });
                         pointFeatureLayer = new FeatureLayer("http://164.100.133.131/arcgisserver/rest/services/CRD/CRD2/FeatureServer/0", { id: "Points"
                         map.addLayers([operationalLayer, pointFeatureLayer]);
                         // Add Table of Contents Start
                       map.on('layers-add-result', function (evt) {
                             try {
                                 var toc = new TOC({
                                     map: map,
                                     layerInfos: [{
                                         layer: pointFeatureLayer,
                                         title: "My Feature"
                                         layer: operationalLayer,
                                         title: "Dynamic Map"
                                 }, "tocDiv");
                                 toc.startup();
                                 toc.on("load", function () {
                                     console.log("TOC loaded");
                             catch (e) { console.error(e.message); }
        </script>
    </head>
    <body class="soria">
        <div id="mapDiv">
            <div id="tocDiv"></div>
        </div>
    </body>
    </html>
RobertScheitlin__GISP
Veena,
   Your code seems to be missing.
veenahosur1
New Contributor II
    <!DOCTYPE html>
    <html>
    <head>
        <style>
                padding: 0;
                margin: 0;
                height: 100%;
                width: 100%;
                overflow: hidden;
            #tocDiv {
                z-index: 50;
                position: absolute;
                top: 0%;
                left: 0%;
                width: 300px;
                height: auto;
            #divDialogProcess {
                z-index: 50;
                position: absolute;
                right: 0%;
                top: 0%;
        </style>
        <script>
            var dojoConfig = {
                packages: [{
        </script>
        <script>
                     "dojo/dom",
                     "dojo/fx",
                     "dojo/on",
                     "dojo/parser",
                     "dojo/_base/Color",
                     "agsjs/dijit/TOC",
                     center: [77.2, 14],
                     zoom: 7,
                     basemap: "topo",
                     slider: false
                         operationalLayer = new ArcGISDynamicMapServiceLayer("http:/..../MapServer", { id: "Operational", opacity: 0.5 });
                         pointFeatureLayer = new FeatureLayer("http://../FeatureServer/0", { id: "Points"
                             try {
                                 var toc = new TOC({
                                     map: map,
                                     layerInfos: [{
                                         title: "My Feature"
                                 }, "tocDiv");
                                 toc.startup();
        </script>
    </head>
        <div id="mapDiv">
        </div>
    </body>
    </html>
Veena,
  Here is you code working:
<!DOCTYPE html>
<html>
<head>
  <link rel="stylesheet" href="http://js.arcgis.com/3.15/esri/css/esri.css">
  <style>
    html,
    body,
    #mapDiv {
      padding: 0;
      margin: 0;
      height: 100%;
      width: 100%;
      overflow: hidden;
    #tocDiv {
      z-index: 50;
      position: absolute;
      top: 0%;
      left: 0%;
      width: 300px;
      height: auto;
    #divDialogProcess {
      z-index: 50;
      position: absolute;
      right: 0%;
      top: 0%;
  </style>
  <script>
    var dojoConfig = {
      paths: {
        agsjs: "http://gmaps-utility-gis.googlecode.com/svn/tags/agsjs/latest/build/agsjs"
  </script>
  <script src="http://js.arcgis.com/3.15/"></script>
  <script>
    require([
      "esri/map",
      "esri/config",
      "dojo/dom",
      "dojo/fx",
      "dojo/on",
      "dojo/parser",
      "dojo/_base/Color",
      "agsjs/dijit/TOC",
      "dojo/domReady!"
    ], function (
        center: [77.2, 14],
        zoom: 7,
        basemap: "topo",
        slider: false
      operationalLayer = new ArcGISDynamicMapServiceLayer("http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/PublicSafety/PublicSafetyOperationalLayer...", {
        opacity: 0.5
      pointFeatureLayer = new FeatureLayer("http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Demographics/ESRI_Census_USA/MapServer/1", {
        try {
          var toc = new TOC({
            map: map,
            layerInfos: [{
              title: "My Feature"
          }, "tocDiv");
          toc.startup();
        } catch (e) {
  </script>
</head>
  <div id="mapDiv">
  </div>
</body>
</html>
veenahosur1
New Contributor II
its not working for me
Veena,
   The sample I provided is working and tested on my end. Did you zoom out and move to the US where the sample map service data is located? I did not adjust the maps extent from where you had it set so that it would be easier for you to just replace the service urls with your own.
