Hello all!
I was using the code from this tutorial Build a web map using ArcGIS.com | Guide | ArcGIS API for JavaScript - the only thing I changed was the ID to my public map, so I use ID=2238835174444ac081bc6881de191445
When running in browser (Firefox and Chrome) it does not show the legend and the title/subtitle properly (they are truncated) as per the image below
However, after I re-size the browser window and then maximize, it is shown properly
Any idea what is wrong here?
UPDATE: Actually neither the original sample code from the tutorial does not work, it has the same problem. I am using Tomcat to run my web app.
thank you
Sorin
