Is it possible to modify the symbolization of a class breaks renderer? My map has a feature layer with a class breaks render. I'd like to change the class breaks renderer based on user input when a user changes a dropdown selection. When I remove break info and add new break info, and do a refresh on the feature layer, nothing happens on the map. If I zoom or pan I can see the legend change, but the map still looks the same. Do I need to redraw the map or do a different sort of refresh?
Code example is below"
var myFeatureLayer = new FeatureLayer(myurl, {
definitionExpression: "ID = 0",
listMode: "hide",
outFields: ["*"],
opacity: 1.0,
popupTemplate: myPopupTemplate,
renderer: myClassBreaksRenderer,
title: "Locations"
var myClassBreaksRenderer = new ClassBreaksRenderer({
type: "class-breaks",
field: "myField"
myClassBreaksRenderer.addClassBreakInfo({
minValue: 0,
maxValue: 21.0,
symbol: {
type: "simple-marker",
color: [255, 255, 255, 1],
outline: {
color: "yellow",
width: 4
minValue: 22.0,
maxValue: 27.0,
symbol: {
outline: {
color: "orange",
width: 4
minValue: 28.0,
maxValue: 29.0,
symbol: {
outline: {
color: "darkred",
width: 4
map.add(myFeatureLayer);
// code below is to remove the original 0-21 yellow marker and add a green
// marker to replace it.
$("#mySelect").change(function () {
myClassBreaksRenderer.removeClassBreakInfo(0, 21.0);
minValue: 0,
maxValue: 21.0,
symbol: {
outline: {
color: "green",
width: 4
// expect to see the symbol change but there is not visible difference
myFeatureLayer.refresh();
