Cross domain request....
860
07-24-2010 08:47 PM
GISAdmin1
New Contributor III
I would like to retrieve the JSON results of a REST identify request using something like a xmlhttprequest.  The problem is, my ArcGIS Server is not on the same domain, so, my request will fail (cross domain).  Does anyone have any suggestions on how to grab the JSON from a REST call and use it via Javascript?
Thanks in advance,
M
RahulRavikumar
This has already been baked into the JavaScript API. You can use an esri namespace method called "esri.request(...)"
The full API reference documentation for the method is at : http://http://help.arcgis.com/en/webapi/javascript/arcgis/help/jsapi/namespace_esri.htm#request
esri.request({
  url:"http://..../rest/services/USA/MapServer",
  content: {
    param1: "value1",
    param2: "value2",
    param3: "value3"
  callbackParamName:"callback",
  load:function(response, io) {
  error:esriConfig.defaults.io.errorHandler
__Rich_
Occasional Contributor III
(I'm not sure Rahul's understood the issue you're facing?)
You'll need to satisfy 'same origin policy', you could achieve this by employing a proxy, e.g. the 'stock' proxy page should be be all you require for your particular needs.
HTH 🙂
DavidHollema
New Contributor III
When you say this has been "baked into the JavaScript API"...I'm curious what that means?  How are cross-domain requests performed without a proxy page?  Is it using jsonp and script tag injection?
esri.request({
  content: {
    param1: "value1",
    param2: "value2",
    param3: "value3"
