Hi, I am new to ArcGIS JavaScript API, I would like to create custom tool on my web app, I search internet, it seems all I can find is custom widget, for example I want to develop custom tool when click the map just display the x, y values in a custom dialog showing where the mouse clicked, and query the feature layer. how can I get started? The following is the sample I took from esri website and I want to add my custom tool to the group, but it does not work. I don't know what I did wrong here, Can anyone help? Thank you in advance.
Dave
<!DOCTYPE html>
<html>
<head>
<meta http-equiv="Content-Type" content="text/html; charset=utf-8">
<meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no">
<title>Shapes and Symbols</title>
<link rel="stylesheet" href="https://js.arcgis.com/3.16/esri/css/esri.css">
<style>
#info {
top: 20px;color: #444;height: auto; font-family: arial;right: 20px; margin: 5px;
padding: 10px; position: absolute; width: 115px; z-index: 40; border: solid 2px #666;
border-radius: 4px; background-color: #fff;
html, body, #mapDiv { padding:0; margin:0; height:100%; }
button { display: block; }
</style>
<script src="https://js.arcgis.com/3.16/"></script>
<script>
var map, tb;
require([
"esri/map", "esri/toolbars/draw",
"esri/symbols/SimpleMarkerSymbol", "esri/symbols/SimpleLineSymbol",
"esri/symbols/PictureFillSymbol", "esri/symbols/CartographicLineSymbol",
"esri/graphic", "esri/Color", "dojo/dom", "dojo/on", "dojo/domReady!"
], function(
Map, _Draw,
SimpleMarkerSymbol, SimpleLineSymbol, PictureFillSymbol, CartographicLineSymbol,
_Graphic, Color, dom, on
map = new Map("mapDiv", {
basemap: "streets",
center: [-25.312, 34.307],
zoom: 3
map.on("load", initToolbar);
// markerSymbol is used for point and multipoint, see http://raphaeljs.com/icons/#talkq for more examples
var markerSymbol = new SimpleMarkerSymbol();
markerSymbol.setPath("M16,4.938c-7.732,0-14,4.701-14,10.5c0,1.981,0.741,3.833,2.016,5.414L2,25.272l5.613-1.44c2.339,1.316,5.237,2.106,8.387,2.106c7.732,0,14-4.701,14-10.5S23.732,4.938,16,4.938zM16.868,21.375h-1.969v-1.889h1.969V21.375zM16.772,18.094h-1.777l-0.176-8.083h2.113L16.772,18.094z");
markerSymbol.setColor(new Color("#00FFFF"));
// lineSymbol used for freehand polyline, polyline and line.
var lineSymbol = new CartographicLineSymbol(
CartographicLineSymbol.STYLE_SOLID,
new Color([255,0,0]), 10,
CartographicLineSymbol.CAP_ROUND,
CartographicLineSymbol.JOIN_MITER, 5
// fill symbol used for extent, polygon and freehand polygon, use a picture fill symbol
// the images folder contains additional fill images, other options: sand.png, swamp.png or stiple.png
var fillSymbol = new PictureFillSymbol("images/mangrove.png",
new SimpleLineSymbol(SimpleLineSymbol.STYLE_SOLID,new Color('#000'),1), 42, 42);
function initToolbar() {
tb = new _Draw(map);
tb.on("draw-end", addGraphic);
// event delegation so a click handler is not
// needed for each individual button
on(dom.byId("info"), "click", function(evt) {
//alert(evt.target.id); //show up
if ( evt.target.id === "info" ) {
return;
var tool = evt.target.id.toLowerCase();
map.disableMapNavigation();
if(tool != "mycustomtool")
tb.activate(tool);
else
on(map, "click", function Map_Click() { alert("custom tool"); } ) //this will never show up
function addGraphic(evt) {
//deactivate the toolbar and clear existing graphics
tb.deactivate();
map.enableMapNavigation();
// figure out which symbol to use
var symbol;
if ( evt.geometry.type === "point" || evt.geometry.type === "multipoint") {
symbol = markerSymbol;
} else if ( evt.geometry.type === "line" || evt.geometry.type === "polyline") {
symbol = lineSymbol;
else {
symbol = fillSymbol;
map.graphics.add(new _Graphic(evt.geometry, symbol));
</script>
</head>
<body>
<div id="info">
<div>Select a shape then draw on map to add graphic</div>
<button id="Point">Point</button>
<button id="Multipoint">Multipoint</button>
<button id="Line">Line</button>
<button id="Polyline">Polyline</button>
<button id="FreehandPolyline">Freehand Polyline</button>
<button id="Triangle">Triangle</button>
<button id="Extent">Rectangle</button>
<button id="Circle">Circle</button>
<button id="Ellipse">Ellipse</button>
<button id="Polygon">Polygon</button>
<button id="FreehandPolygon">Freehand Polygon</button>
<button id="MyCustomeTool">Custom tool</button>
</div>
<div id="mapDiv"></div>
</body>
</html>
