custom map tool javasctipt
5163
10
06-07-2016 03:11 PM
Dave_J_Zhang
Hi, I am new to ArcGIS JavaScript API, I would like to create custom tool on my web app, I search internet, it seems all I can find is custom widget, for example I want to develop custom tool when click the map just display the x, y values in a custom dialog showing where the mouse clicked, and query the feature layer. how can I get started? The following is the sample I took from esri website and I want to add my custom tool to the group, but it does not work. I don't know what I did wrong here, Can anyone help? Thank you in advance.
Dave
<!DOCTYPE html>
<html>
  <head>
    <title>Shapes and Symbols</title>
    <link rel="stylesheet" href="https://js.arcgis.com/3.16/esri/css/esri.css">
    <style>
      #info {
        top: 20px;color: #444;height: auto;  font-family: arial;right: 20px;  margin: 5px;
        padding: 10px;  position: absolute;  width: 115px;  z-index: 40;  border: solid 2px #666;
        border-radius: 4px;   background-color: #fff;
      html, body, #mapDiv {    padding:0;    margin:0;      height:100%;  }
      button {  display: block;  }
    </style>
    <script src="https://js.arcgis.com/3.16/"></script>
    <script>
      var map, tb;
      require([
        "esri/map", "esri/toolbars/draw",
        "esri/symbols/SimpleMarkerSymbol", "esri/symbols/SimpleLineSymbol",
        "esri/symbols/PictureFillSymbol", "esri/symbols/CartographicLineSymbol",
        "esri/graphic", "esri/Color", "dojo/dom", "dojo/on", "dojo/domReady!"
      ], function(
        Map, _Draw,
        SimpleMarkerSymbol, SimpleLineSymbol, PictureFillSymbol, CartographicLineSymbol,
        _Graphic, Color, dom, on
        map = new Map("mapDiv", {
          basemap: "streets",
          center: [-25.312, 34.307],
          zoom: 3
        map.on("load", initToolbar);
        // markerSymbol is used for point and multipoint, see http://raphaeljs.com/icons/#talkq for more examples
        var markerSymbol = new SimpleMarkerSymbol();
        markerSymbol.setPath("M16,4.938c-7.732,0-14,4.701-14,10.5c0,1.981,0.741,3.833,2.016,5.414L2,25.272l5.613-1.44c2.339,1.316,5.237,2.106,8.387,2.106c7.732,0,14-4.701,14-10.5S23.732,4.938,16,4.938zM16.868,21.375h-1.969v-1.889h1.969V21.375zM16.772,18.094h-1.777l-0.176-8.083h2.113L16.772,18.094z");
        markerSymbol.setColor(new Color("#00FFFF"));
        // lineSymbol used for freehand polyline, polyline and line.
        var lineSymbol = new CartographicLineSymbol(
          CartographicLineSymbol.STYLE_SOLID,
          new Color([255,0,0]), 10,
          CartographicLineSymbol.CAP_ROUND,
          CartographicLineSymbol.JOIN_MITER, 5
        // fill symbol used for extent, polygon and freehand polygon, use a picture fill symbol
        // the images folder contains additional fill images, other options: sand.png, swamp.png or stiple.png
        var fillSymbol = new PictureFillSymbol("images/mangrove.png",
          new SimpleLineSymbol(SimpleLineSymbol.STYLE_SOLID,new Color('#000'),1), 42, 42);
        function initToolbar() {
          tb = new _Draw(map);
          tb.on("draw-end", addGraphic);
          // event delegation so a click handler is not
          // needed for each individual button
          on(dom.byId("info"), "click", function(evt) {
            //alert(evt.target.id); //show up
            if ( evt.target.id === "info" ) {
              return;
            var tool = evt.target.id.toLowerCase();
            map.disableMapNavigation();
            if(tool != "mycustomtool")
                tb.activate(tool);
            else
                  on(map, "click", function Map_Click()  {  alert("custom tool");  } )  //this will never show up
        function addGraphic(evt) {
          //deactivate the toolbar and clear existing graphics
          tb.deactivate();
          map.enableMapNavigation();
          // figure out which symbol to use
          var symbol;
          if ( evt.geometry.type === "point" || evt.geometry.type === "multipoint") {
            symbol = markerSymbol;
          } else if ( evt.geometry.type === "line" || evt.geometry.type === "polyline") {
            symbol = lineSymbol;
          else {
            symbol = fillSymbol;
          map.graphics.add(new _Graphic(evt.geometry, symbol));
    </script>
  </head>
  <body>
    <div id="info">
      <div>Select a shape then draw on map to add graphic</div>
      <button id="Point">Point</button>
      <button id="Multipoint">Multipoint</button>
      <button id="Line">Line</button>
      <button id="Polyline">Polyline</button>
      <button id="FreehandPolyline">Freehand Polyline</button>
      <button id="Triangle">Triangle</button>
      <button id="Extent">Rectangle</button>
      <button id="Circle">Circle</button>
      <button id="Ellipse">Ellipse</button>
      <button id="Polygon">Polygon</button>
      <button id="FreehandPolygon">Freehand Polygon</button>
      <button id="MyCustomeTool">Custom tool</button>
    </div>
    <div id="mapDiv"></div>
  </body>
</html>
PanagiotisPapadopoulos
Hi Dave glad to hear that helped.
Please mark the conversation as answered for future searches.
Add a listener in order to detect the mouse events (move , click e.t.c)
dojo.connect(map, "onMouseMove", onMapMouseMove);
//for XY coordinates
then onMapMouseMove function take the x, y from the event , convert it to the coordinate you want to show and add this on a div on your interface. below is a sample:
function onMapMouseMove(event){
if (map.spatialReference.isWebMercator()){
  var GeoPOint = esri.geometry.webMercatorToGeographic(event.mapPoint);
  }else{
  var GeoPOint = event.mapPoint;
    var x = GeoPOint.x.toFixed(5);
    var y = GeoPOint.y.toFixed(5);
dojo.byId('mapPosition').innerHTML = dojo.string.substitute('<b>λ:</b> '+'${0}, <b>φ:</b> ${1}', [x, y]);
Dave_J_Zhang
Hi, Panagiotis, Great thanks for your response, I will try out.
Dave_J_Zhang
Thank you for your advice, Panagiotis, my current version legend and dummy custom  tool somewhat working, but I got two errors, like the following:
first error is keep getting following error in first line (<!DOCTYPE html>):
XMLHttpRequest cannot load http://sampleserver3.arcgisonline.com/ArcGIS/rest/info?f=json. No 'Access-Control-Allow-Origin' header is present on the requested resource. Origin 'null' is therefore not allowed access.
also I try to get my dialog box pop up and display the x and y value at where use clicked. but it does not show up. Can you or anyone help me?
I am very appreciate for any sugguestions.
Dave
//the following are codes I currently have.
<!DOCTYPE html>
<html>
<head>
  <title>Map with legend</title>
  <link rel="stylesheet" href="https://js.arcgis.com/3.16/dijit/themes/claro/claro.css">
  <style>
    html, body {
      height: 97%;
      width: 98%;
      margin: 1%;
    #rightPane {
      width: 20%;
    #legendPane {
      border: solid #97DCF2 1px;
  </style>
  <script>
    var map, currTool;
//require(["esri/config"], function(esriConfig) { esriConfig.defaults.io.corsDetection = false; });
require(["esri/tasks/GeometryService","esri/tasks/ProjectParameters"], function(GeometryService, ProjectParameters){
var params = new ProjectParameters();
//params.geometries = [point];
//params.outSR = outSR;
//params.transformation = transformation;
//gsvc.project(params);  //
require(["dijit/form/Button"], function(Button) {   });
require(["dijit/Dialog", "dijit/form/TextBox", "dijit/form/Button"]);
    require([
      "esri/map", "esri/layers/FeatureLayer", "esri/dijit/Legend",
      "dojo/_base/array", "dojo/parser",
      "dijit/layout/BorderContainer", "dijit/layout/ContentPane",
      "dijit/layout/AccordionContainer", "dojo/domReady!"
    ], function(
      Map, FeatureLayer, Legend,
      arrayUtils, parser
      parser.parse();
      map = new Map("map", {
        basemap:"topo",
        center: [-96.53, 38.374],
        zoom: 13
      var rivers = new FeatureLayer("https://sampleserver3.arcgisonline.com/ArcGIS/rest/services/Hydrography/Watershed173811/MapServer/1", {
        mode: FeatureLayer.MODE_ONDEMAND,
        outFields:["*"]
      var waterbodies = new FeatureLayer("https://sampleserver3.arcgisonline.com/ArcGIS/rest/services/Hydrography/Watershed173811/MapServer/0", {
        outFields:["*"]
      //add the legend
      map.on("layers-add-result", function (evt) {
        var layerInfo = arrayUtils.map(evt.layers, function (layer, index) {
          return {layer:layer.layer, title:layer.layer.name};
        if (layerInfo.length > 0) {
          var legendDijit = new Legend({
            map: map,
            layerInfos: layerInfo
          }, "legendDiv");
          legendDijit.startup();
   map.on("click", function (evt) {
        handle_mapEvents(evt);
      map.addLayers([waterbodies, rivers]);
function handle_customTool()
  //myDialog.show(); //does show up
  currTool = "customTool";
function handle_mapEvents(evt){
if(currTool === "customTool")
     var GeoPOint;
  //if (map.spatialReference.isWebMercator())
   GeoPOint = evt.mapPoint; //esri.geometry.webMercatorToGeographic(event.mapPoint);
   var x = GeoPOint.x.toFixed(5); //Deferred long-running timer task(s) to improve scrolling smoothness. See crbug.com/574343.
   alert("mouse click location is: (" + x + "," + y + ")"); //works
   //alert(GeoPOint.spatialReference.latestWkid);//works
   //alert(view.spatialReference.wkid)//works
   //The following three line code does not working ????????????
   dijit.byId("txt_X").innerHTML = "" + x;
   dijit.byId("txt_Y").innerHTML = "" + y;
   dijit.byId("myDialog").show(); //
  }else
   alert("will execute other tool action");
  </script>
</head>
<body class="claro">
<!--[if IE 7]>
<style>
  html, body {
    margin: 0;
</style>
<![endif]-->
<div data-dojo-type="dijit/Dialog" data-dojo-id="myDialog" title="My Custom Tool">
     <table>
                    <tr>
                        <td><LABEL for="X:">X: </LABEL></td>
                        <td><INPUT type="text" data-dojo-type="dijit/form/TextBox" id="txt_X"></td>
                    </tr>
                    <tr>
                        <td><LABEL for="Y:">Y: </LABEL></td>
                        <td><INPUT type="text" data-dojo-type="dijit/form/TextBox" id="txt_Y"></td>
                    </tr>
     </table>
</div>
<div id="content"
     data-dojo-type="dijit/layout/BorderContainer"
     data-dojo-props="design:'headline', gutters:true"
     style="width: 100%; height: 100%; margin: 0;">
  <div id="rightPane"
       data-dojo-type="dijit/layout/ContentPane"
       data-dojo-props="region:'right'">
    <div data-dojo-type="dijit/layout/AccordionContainer">
      <div data-dojo-type="dijit/layout/ContentPane" id="legendPane"
           data-dojo-props="title:'Legend', selected:true">
        <div id="legendDiv"></div>
      </div>
           data-dojo-props="title:'Tools'">
     <button data-dojo-type="dijit/form/Button" type="button" onClick="handle_customTool();">My custom tool</button>
    </div>
    </div>
  </div>
  <div id="map"
       data-dojo-props="region:'center'"
       style="overflow:hidden;">
  </div>
</div>
</body>
</html>
Hi Dave
see the following  Edit fiddle - JSFiddle
something happened with Dialog box. I placed the Table on below Custom tool button
also you can place the Y,X table inside map and allow user to see mouse coords on mouse move
Dave_J_Zhang
Hi, PanagiotisPanagiotis Papadopoulos
Thank you for reply, I am trying so hard to make it pop up as a dialog box and can be drag around.
what I did wrong here?
Hi Dave
see the following with Dialog enabled
Also try to use jQuery for User Interface
Dave_J_Zhang
Hi, Panagiotis
   Thank you for your reply, this help me a lot on my project. I really appreciate your help.
Dave
