DataGrid
4919
15
03-04-2015 03:11 PM
JimBob3
I have a geprocessing service that returns JSON that I am attempting to put into a datagrid.
Snippet of JSON from GP service:
Here is the relevant code:
 map.on("load", initSelectionToolbar);
            registry.byId("point").on("click", function() {
                activateTool(this.id);
            function initSelectionToolbar() {
                map.graphics.clear();
                selectionToolbar = new Draw(map);
                selectionToolbar.on("draw-end", function(e) {
                    selectionToolbar.deactivate();
                    var symbol = new SimpleMarkerSymbol(
                        SimpleMarkerSymbol.STYLE_CIRCLE,
                        16,
                        new SimpleLineSymbol(
                            SimpleLineSymbol.STYLE_SOLID,
                            new Color([89, 95, 35]), 2
                        new Color([130, 159, 83, 0.40])
                    var graphic = new Graphic(e.geometry, symbol);
                    map.graphics.add(graphic);
                    map.infoWindow.hide();
            function activateTool(tool) {
                // The draw.activate expects a string like "polygon" or "freehand_polygon".
                selectionToolbar.activate(tool);
            registry.byId("searchSPs").on("click", searchSPs);
            function searchSPs() {
                var geom = map.graphics
                var dist = dom.byId("distance").value
                var distUnit = dom.byId("distanceUnits").value
                var params = {
                        pointX: geom.graphics[0].geometry.x,
                        pointY: geom.graphics[0].geometry.y,
                        buffer: dist,
                        unitType: distUnit
                gp.submitJob(params, completeCallback, statusCallback);
            function statusCallback(jobInfo) {
                console.log(jobInfo.jobStatus);
            function completeCallback(jobInfo) {
                var id = jobInfo.jobId
                var data = gp.getResultData.id
                var stuff = gp.getResultData(id, "output", displaySPs);
            function displaySPs(outputFile) {
                var searchS = outputFile.value.SPs;
                searchS.sort(function(a, b) {
                    return a.Distance - b.Distance
  //tried this, does not work.
                // var items = arrayUtils.map(searchS, function(result) {
                //   return result;
                var items = []
                items = searchS;
                var data = {
                    idProperty: "output", //This field needs to have unique values
                    label: "StationID", //Name field for display. Not pertinent to a grid but may be used elsewhere.
                    items: items
                store = new ItemFileReadStore({
  //either way behaves the same way.
                    //data: {identifier: 'StationID', items: items}
                    data: data
                var grid = registry.byId("grid");
                //identifier present in the store.
                grid.store = store
                //no identifier in the store, even though it is present.
                //window.grid.set("store", items);
  //this does not work.
                //grid.setStore(store);
and the HTML:
<div id="rightPane" class="shadow roundedCorners" data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'right'">
            <button id="point" data-dojo-type="dijit/form/Button">Select Point</button>
            <br> Search Distance:
            <input type="text" id="distance" size="5" value="200" />
            <select data-dojo-type="dijit/form/Select" id="distanceUnits">
                <option value="feet">Feet</option>
                <option value="meters">Meters</option>
            </select>
            <br>
            <button id="searchSPs" data-dojo-type="dijit/form/Button" value="searchSPs">Search Splice Points</button>
            <br>
            <table data-dojo-type="dojox/grid/DataGrid" data-dojo-id="grid" id="grid" style="width:100%;height:100%; data-dojo-props=" rowsPerPage: '10', rowSelector: '20px' " class="roundedCorners shadow ">
                        <thead>
                            <tr>
                                <th field="StationID ">Station ID</th>
                                <th field="Subtype ">Subtype</th>
                                <th field="Distance ">Distance (meters)</th>
                            </tr>
                        </thead>
                    </table>
        </div>
When I check the datastore in the console here is what I see
No matter what I do though the datagrid is not updated with the values I am looking for.  Any thoughts?
Jim
JimBob3
Robert,
Here is JSON from the geoprocessing service.
"paramName": "output",
"dataType": "GPString",
"value": {"SplicePoints": [
  "Distance": 58.602883696309995,
  "Placing_Workorder": "ENG-2-CODE",
  "SP_GUID": "10bf67d1-703c-449a-b7db-6a3dbf2743ee",
  "SP_OID": 71,
  "SplicePointX": -9043344.1822,
  "SplicePointY": 2189184.3605999984,
  "StationID": "SVH-4/1/7",
  "Status": 101,
  "Subtype": "Pedestal"
  "Distance": 23.187442940860507,
  "SP_GUID": "8fc0139f-0c45-4ff2-969d-ad1a596e08a9",
  "SP_OID": 110,
  "SplicePointX": -9043393.7766,
  "SplicePointY": 2189197.5232000016,
  "StationID": "SVH-4/1/5-5",
  "Status": 101,
Jim
RobertScheitlin__GISP
Jim,
  Here I took your json data and manipulated the dgrid sample ​from the JS API to use your data.
<!DOCTYPE html>
<html>
<head>
  <meta charset="utf-8">
  <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no">
  <title>Map with a Dojo dGrid</title>
  <link rel="stylesheet" href="http://js.arcgis.com/3.12/dojo/resources/dojo.css">
  <link rel="stylesheet" href="http://js.arcgis.com/3.12/dgrid/css/dgrid.css">
  <link rel="stylesheet" href="http://js.arcgis.com/3.12/dgrid/css/skins/tundra.css">
  <link rel="stylesheet" href="http://js.arcgis.com/3.12/dijit/themes/tundra/tundra.css">
  <link rel="stylesheet" href="http://js.arcgis.com/3.12/esri/css/esri.css">
  <style>
    html,
    body {
      height: 100%;
      width: 100%;
      margin: 0;
      padding: 0;
      overflow: hidden;
    #container {
      height: 100%;
      visibility: hidden;
    #bottomPane {
      height: 200px;
    #grid {
      height: 100%;
    .dgrid {
      border: none;
    .field-id {
      cursor: pointer;
  </style>
  <script src="http://js.arcgis.com/3.12/"></script>
  <script>
    // load dgrid, esri and dojo modules
    // create the grid and the map
    // then parse the dijit layout dijits
    require([
      "dojo/ready",
      "dgrid/OnDemandGrid",
      "dgrid/Selection",
      "dojo/store/Memory",
      "dojo/_base/array",
      "dojo/dom-style",
      "dijit/registry",
      "esri/map",
      "esri/layers/FeatureLayer",
      "esri/symbols/SimpleFillSymbol",
      "esri/tasks/QueryTask",
      "esri/tasks/query",
      "dojo/_base/declare",
      "dojo/number",
      "dojo/on",
      "dojo/parser",
      "dijit/layout/BorderContainer",
      ], function (
      ready,
      Grid,
      Selection,
      Memory,
      array,
      domStyle,
      registry,
      Map,
      FeatureLayer,
      SimpleFillSymbol,
      QueryTask,
      Query,
      declare,
      dojoNum,
      on,
      parser
      ready(function () {
        parser.parse();
        // create the dgrid
        window.grid = new(declare([Grid, Selection]))({
          // use Infinity so that all data is available in the grid
          bufferRows: Infinity,
          columns: {
            "id": "ID",
            "StationID": "Station ID",
            "Distance": {
              "label": "Splice Distance",
              "formatter": dojoNum.format
            "Subtype": "Sub Type"
        }, "grid");
        window.map = new Map("map", {
          basemap: "streets",
          center: [-101.426, 42.972],
          zoom: 4
        window.output = {
          "value": {
            "SplicePoints": [
                "SP_OID": 71,
                "Status": 101,
                "SP_OID": 110,
                "Status": 101,
        map.on("load", function (evt) {
          // show the border container now that the dijits
          // are rendered and the map has loaded
          domStyle.set(registry.byId("container").domNode, "visibility", "visible");
          populateGrid(Memory); // pass a reference to the MemoryStore constructor
        function populateGrid(Memory) {
          var data = array.map(window.output.value.SplicePoints, function (sp) {
            return {
              // property names used here match those used when creating the dgrid
              "id": sp.SP_OID,
              "StationID": sp.StationID,
              "Distance": sp.Distance,
              "Subtype": sp.Subtype
          var memStore = new Memory({
            data: data
          window.grid.set("store", memStore);
  </script>
</head>
<body class="tundra">
  <div id="container" data-dojo-type="dijit/layout/BorderContainer" data-dojo-props="design: 'headline', gutters: false">
    <div id="map" data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region: 'center'"></div>
    <div id="bottomPane" data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region: 'bottom'">
      <div id="grid"></div>
    </div>
  </div>
</body>
</html>
JimBob3
Hi Robert,
Thank you for the suggestion. Here is the new updated code using your suggestion:
    columns: {
        "id": "ID",
        "Distance": {
}, "grid");
            16,
registry.byId("searchSplicePoints").on("click", searchSplicePoints);
function searchSplicePoints() {
    var params = {
        buffer: dist,
        unitType: distUnit
    var stuff = gp.getResultData(id, "output", displaySplicePoints);
function displaySplicePoints(outputFile) {
    var searchSplice = outputFile.value.SplicePoints;
    console.log(searchSplice);
    searchSplice.sort(function(a, b) {
    var data = arrayUtils.map(searchSplice, function(sp) {
        return {
            "id": searchSplice.SP_OID,
            "StationID": searchSplice.StationID,
            "Distance": searchSplice.Distance,
            "Subtype": searchSplice.Subtype
    console.log(data);
        data: data
The datagrid now displays the cells, however they are empty. When I check my console, I can see searchSplice has information, but data has everything undefined.
Jim,
OK you need to pay close attention to your code.
You have:
        return {
So you are looping over the searchSplice array and when you do that using arrayUtils.map you are defining a var for each object in that array and the vars name in the code is sp not searchSplice, because searchSplice is the whole array and not the individual object of the array.
So it should be:
        return {
            "id": sp.SP_OID,
JimBob3
*sigh*
Thanks Robert.  That worked.
Stupid thing to miss, but at least it now populates the grid correctly.
Jim
Jim,
Glad to help.
  1. Now it is your turn to help the community by marking this question as answered. All you have to do is click the "Correct Answer" link (the one with the little green star) on the post that provided the answer for you.
  2. If the answer was not provided by one of the responders then you can mark any of the replies that you received as helpful by clicking on the "Actions" menu and choosing "Mark as Helpful"
