Jim,
Here is a sample that I added setMinScale to a ArcGISDynamicMapServiceLayer and it works fine.
The scale is set to the oilandgas layer and it will not show in the map until you zoom in to get beyond 120000.
Line 139 is where setMinScale is used.
<!DOCTYPE html>
<html>
<head>
<meta http-equiv="Content-Type" content="text/html; charset=utf-8">
<meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no">
<meta name="apple-mobile-web-app-capable" content="yes">
<meta name="apple-mobile-web-app-status-bar-style" content="black-translucent">
<meta name="mobile-web-app-capable" content="yes">
<title>ArcGIS dynamic and tile layers using Popup and InfoTemplates</title>
<link rel="stylesheet" href="https://js.arcgis.com/3.17/esri/css/esri.css">
<style>
html, body, #ui-esri-map {
width: 100%;
height: 100%;
margin: 0;
padding: 0;
#ui-esri-dijit-geocoder {
top: 20px;
left: 70px;
position: absolute;
z-index: 3;
.esriPopup .titlePane {
text-shadow: none;
.esriPopup .titleButton.next {
right: 40px;
.esriPopup .titleButton.prev {
right: 53px;
.demographicInfoContent {
padding-top: 10px;
.demographicInnerSpacing {
display: inline-block;
width: 8px;
.demographicNumericPadding {
width: 90px;
text-align: right;
</style>
<script src="https://js.arcgis.com/3.17/"></script>
<script>
var map;
require([
"dojo/dom-construct",
"esri/Color",
"esri/dijit/Geocoder",
"esri/dijit/Popup",
"esri/InfoTemplate",
"esri/layers/ArcGISDynamicMapServiceLayer",
"esri/map",
"esri/symbols/SimpleFillSymbol",
"esri/symbols/SimpleLineSymbol", "dojo/domReady!"
], function(
domConstruct, Color, Geocoder, Popup, InfoTemplate,
ArcGISDynamicMapServiceLayer, Map, SimpleFillSymbol, SimpleLineSymbol
var sls = new SimpleLineSymbol("solid", new Color("#444444"), 3);
var sfs = new SimpleFillSymbol("solid", sls, new Color([68, 68, 68, 0.25]));
var popup = new Popup({
fillSymbol: sfs,
lineSymbol: null,
markerSymbol: null
}, domConstruct.create("div"));
map = new Map("ui-esri-map", {
basemap: "topo",
center: [-94.75290067627297, 39.034671990514816], // long, lat
zoom: 12,
sliderStyle: "small",
infoWindow: popup
var geocoder = new Geocoder({
arcgisGeocoder: {
placeholder: "Search "
map: map
}, "ui-esri-dijit-geocoder");
var _countyCensusInfoTemplate = new InfoTemplate();
_countyCensusInfoTemplate.setTitle("<b>Census Information</b>");
var _blockGroupInfoTemplate = new InfoTemplate();
_blockGroupInfoTemplate.setTitle("<b>Census Information</b>");
var _censusInfoContent =
"<div class=\"demographicInfoContent\">" +
"<div class='demographicNumericPadding'>${AGE_5_17:formatNumber}</div><div class=\"demographicInnerSpacing\"></div>people ages 5 - 17<br>" +
"<div class='demographicNumericPadding'>${AGE_40_49:formatNumber}</div><div class=\"demographicInnerSpacing\"></div>people ages 40 - 49<br>" +
"<div class='demographicNumericPadding'>${AGE_65_UP:formatNumber}</div><div class=\"demographicInnerSpacing\"></div>people ages 65 and older" +
"</div>";
_countyCensusInfoTemplate.setContent("Demographics for:<br>${NAME} ${STATE_NAME:getCounty}, ${STATE_NAME}<br>" + _censusInfoContent);
_blockGroupInfoTemplate.setContent("Demographics for:<br>Tract: ${TRACT:formatNumber} Blockgroup: ${BLKGRP}<br>" + _censusInfoContent);
var _oilAndGasInfoTemplate = new InfoTemplate();
_oilAndGasInfoTemplate.setTitle("<b>Oil and Gas data</b>");
var _oilAndGasInfoContent =
"Gas production: ${PROD_GAS}<br>Oil production: ${PROD_OIL:formatNumber}" +
"</div>";
_oilAndGasInfoTemplate.setContent("${FIELD_NAME} production field<br>" +
_oilAndGasInfoContent);
var demographicsLayerURL = "https://sampleserver6.arcgisonline.com/arcgis/rest/services/Census/MapServer";
var demographicsLayerOptions = {
"id": "demographicsLayer",
"opacity": 0.8,
"showAttribution": false
var demographicsLayer = new ArcGISDynamicMapServiceLayer(demographicsLayerURL, demographicsLayerOptions);
demographicsLayer.setInfoTemplates({
1: { infoTemplate: _blockGroupInfoTemplate },
2: { infoTemplate: _countyCensusInfoTemplate }
demographicsLayer.setVisibleLayers([1, 2]);
map.addLayer(demographicsLayer);
var oilAndGasLayer = new ArcGISDynamicMapServiceLayer("https://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Petroleum/KGS_OilGasFields_Kansas/MapSer...", {
"id": "oilAndGasLayer",
"opacity": 0.75
oilAndGasLayer.setMinScale(120000);
oilAndGasLayer.setInfoTemplates({
0: { infoTemplate: _oilAndGasInfoTemplate }
map.addLayer(oilAndGasLayer);
geocoder.startup();
var formatNumber = function(value, key, data) {
var searchText = "" + value;
var formattedString = searchText.replace(/(\d)(?=(\d\d\d)+(?!\d))/gm, "$1,");
return formattedString;
var getCounty = function(value, key, data) {
if (value.toUpperCase() !== "LOUISIANA") {
return "County";
} else {
return "Parish";
</script>
</head>
<body>
<div id="ui-esri-map"></div>
<div id="ui-esri-dijit-geocoder"></div>
</body>
</html>
