ESRI proxy page not working properly + CORS + cross domain scripting
2954
09-12-2013 06:28 AM
vinayb
HI All,
     I have setup proxy page , i am using jsp version of proxy page.I have setup server url which will point to my java ,when i load the my page which proxy url set in its html i will work fine only in IE but not in mozilla and chrome.
Even in IE it will work only if i use localhost but if i use my ip then it wont work.
in chrome i get Origin http:// is not allowed by Access-Control-Allow-Origin.
in mozilla when i check the response it get login page of the rest services.
is this issue related to cross domain or what please help.
I haven't check if my proxy is working , question is how do i check it. I think it should be working since in IE when i use localhost instead of my IP it works fine.
In mozilla in firebug when i check i see response being login page for rest service.
I am running my proxy server in my Websphere which is running in port 9080 , my webserver is apache http server which is running at 80 where my arcgis server is running in other machine at port 6080
Proxy server : WebSphere
proxy url : localhost:9080/proxy/proxy.jsp
web server : apache
web server url : localhost
Arcgis server:<some-ip>:6080
Below is completer code
<!DOCTYPE html>
<html>
  <head>
    <meta http-equiv="Content-Type" content="text/html; charset=utf-8">
    <meta http-equiv="X-UA-Compatible" content="IE=7, IE=9, IE=10">
    <!--The viewport meta tag is used to improve the presentation and behavior of the samples
      on iOS devices-->
    <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no">
    <title>FeatureLayer On Demand</title>
    <link rel="stylesheet" href="http://js.arcgis.com/3.6/js/dojo/dijit/themes/claro/claro.css">
    <link rel="stylesheet" href="http://js.arcgis.com/3.6/js/esri/css/esri.css">
    <style>
      html, body, #mapDiv {
        padding:0;
        margin:0;
        height:100%;
    </style>
    <script src="http://js.arcgis.com/3.6/"></script>
    <script>
      var map,featureLayer;
      require(["dojo/on", "esri/map", "esri/layers/ArcGISDynamicMapServiceLayer", "esri/InfoTemplate", "esri/layers/FeatureLayer",
               "esri/symbols/SimpleFillSymbol", "esri/symbols/SimpleLineSymbol", "dojo/_base/Color", "esri/graphic",
               "dojo/parser", "dojo/domReady!"
      ], function(
        on,Map, ArcGISDynamicMapServiceLayer, InfoTemplate, FeatureLayer, SimpleFillSymbol, SimpleLineSymbol, Color, Graphic,
        parser
        parser.parse();
        esri.config.defaults.io.proxyUrl = "http://localhost:9080/proxy/proxy.jsp";
        var initExtent = new esri.geometry.Extent({"xmin":-21744805.806561172,"ymin":-4911537.689490959,"xmax":3302079.6219187006,"ymax":13090911.21222895,"spatialReference":{"wkid":102100}});
        map = new Map("mapDiv", {
          extent: initExtent
        var WorldCountries = new ArcGISDynamicMapServiceLayer("http://10.32.9.106:6080/arcgis/rest/services/KX_Mapping/World_Countries_ESRI_WGS84/MapServer");
        WorldCountries.setDisableClientCaching(true);
        WorldCountries.setOpacity(0.75);
        map.addLayer(WorldCountries);
        showCountries();
        map.on("load", initOperationalLayer);
        function initOperationalLayer() {
         featureLayer = new FeatureLayer("http://10.32.9.106:6080/arcgis/rest/services/KX_Mapping/World_Countries_ESRI_WGS84/MapServer/0",{
            mode: esri.layers.FeatureLayer.MODE_SELECTION,
          outFields: ["*"],
          opacity: 0.75
          var sfs = new SimpleFillSymbol(SimpleFillSymbol.STYLE_FORWARD_DIAGONAL, new SimpleLineSymbol(SimpleLineSymbol.STYLE_SOLID, new Color([255, 0, 0]), 2), new Color([255, 255, 0, 0.5]));
          featureLayer.setSelectionSymbol(sfs);
          map.addLayer(featureLayer);
          map.infoWindow.resize(250,350);
          on(map,"click", function(evt){
                requestData(evt);
                /*var query = new esri.tasks.Query();
                query.geometry = evt.mapPoint;
                featureLayer.selectFeatures(query,esri.layers.FeatureLayer.SELECTION_NEW, function (features){
                    map.infoWindow.setTitle("Country Information");
                    map.infoWindow.setContent("Country Name: " + features[0].attributes.COUNTRY);
                    map.infoWindow.show(evt.screenPoint,map.getInfoWindowAnchor(evt.screenPoint));
      function showCountries(){
            var queryTask = new esri.tasks.QueryTask("http://10.32.9.106:6080/arcgis/rest/services/KX_Mapping/World_Countries_ESRI_WGS84/MapServer/0");
            //build query filter
                console.log(" showCountries");
                        query.returnGeometry = true;
                        query.maxAllowableOffset=calcOffset();
                        query.where = "CNTRY_NAME IN ('India','Brazil','Italy','Australia','France','Libya','Russia','Ukraine','United States','Canada','Zimbabwe','Zambia','Yemen','Vietnam','Venezuela','Vanuatu','Uzbekistan','Uruguay','United States Minor Outlying Islands','United Kingdom','United Arab Emirates','Uganda','Tuvalu','Turks and Caicos Islands','Turkmenistan','Tajikistan','Turkey','Tunisia','Trinidad & Tobago','Tonga','Togo','Timor-Leste','Turkmenistan','Thailand','Tanzania','Palestinian Territory','Panama','Papua New Guinea','Paraguay','Poland','Portugal','Qatar','Romania','Greenland','Mexico','South Africa','South Korea','Spain','Sudan','Sri Lanka','Switzerland','Sweden','St. Vincent & the Grenadines','St. Pierre & Miquelon','Singapore','Indonesia','Colombia','Congo, DRC','Cook Is.','Costa Rica','Croatia','Cyprus','Czech Republic','Cameroon','Democratic Republic of the Congo','Antarctica','Armenia','Austria','North Korea','Romania','Rwanda','Norway','Monaco','Mauritania','Mauritius','Madagascar','Isle of Man','Iceland','Hungary','Germany','Antigua & Barbuda','Azerbaijan','Barbados','Belarus','Belgium','Bermuda','Bhutan','Bosnia & Herzegovina','British Indian Ocean Territory','British Virgin Is.','Central African Republic','Chad','Chile','Christmas I.','Egypt','Ethiopia','Finland','Vatican City','Western Sahara','Syria','Pakistan','Guyana','Mongolia','Nepal','Palau','Jamaica','Italy','Isreal','Fiji','Bermuda','Bhutan','Bolivia','The Bahamas','The Gambia','Montserrat','Mozambique','Morocco','Moldova','Kazakhstan','Myanmar','Sudan','Argentina','Bolivia','Algeria','Niger','Mali','Bolivia','Saudi Arabia','Botswana','Angola')";
                        query.spatialRelationship = esri.tasks.Query.SPATIAL_REL_CONTAINS;
                        //query.spatialRelationship = esri.tasks.Query.SPATIAL_REL_INTERSECTS;
                        var spRef = new esri.SpatialReference({wkid : 102100});
                        query.outSpatialReference = spRef; // Doesn't work
                        //query.outSpatialReference = map.spatialReference; // Doesn't work either
                        infoTemplate = new esri.InfoTemplate("Alert", "Alert for Re-insurance");
                        console.log(" infoTemplate "+infoTemplate);
                        dojo.connect(queryTask, "onComplete", function(featureSet) {
                                try{
                                    console.log(" query complete");
                                    var symbol0 = new esri.symbol.SimpleFillSymbol().setColor(new dojo.Color([255, 0, 0, 0.9]));
                                    dojo.forEach(featureSet.features,function(feature){
                                        //alert('feature'+feature);
                                        var graphic = feature;
                                        graphic.setSymbol(symbol0);
                                        //alert("infoTemplate"+infoTemplate);
                                        graphic.setInfoTemplate(infoTemplate);
                                        //alert("graphic"+graphic);
                                        //alert("map.graphics"+map.graphics);
                                        map.graphics.add(graphic);
                            }catch(e){
                              alert("e"+e);
      queryTask.execute(query);
      function requestData(evt){
            try{
                console.log(" request data");
                dojo.xhrGet({
                    url: "http://earthquake.usgs.gov/earthquakes/feed/geojson/1.0/week",
                    handleAs: 'json',
                    load: function(data){
                                map.infoWindow.setTitle("data[0].properties.place");
                                map.infoWindow.setContent("data[0].properties.mag");
                    error: dojo.hitch(this, "failure")
            }catch(e){
               console.log(e);
      function showData(){
        console.log("in showdata");
      function failure(){
       console.log("failed");
      function calcOffset() {
  return (map.extent.getWidth() / map.width);
  // console.log('extent changed...maxOffset: ', globals.maxOffset);
    </script>
  </head>
  <body class="claro">
    <div id="mapDiv">
    </div>
  </body>
</html>
JonathanUihlein
Hi Vinay! It looks like you've been extremely busy lately.
Don't forget to mark other threads as 'answered' when you've gotten a satisfactory reply 🙂
vinayb
I   am not able to find the option
DossDingli
Have you found a solution to this problem?  We are currently experiencing the same issue.
(using Javascript API with CORS)
JeffJacobson
See the screenshot below...
[ATTACH=CONFIG]28544[/ATTACH]
