HI All, I have setup proxy page , i am using jsp version of proxy page.I have setup server url which will point to my java ,when i load the my page which proxy url set in its html i will work fine only in IE but not in mozilla and chrome.Even in IE it will work only if i use localhost but if i use my ip then it wont work.in chrome i get Origin http:// is not allowed by Access-Control-Allow-Origin.in mozilla when i check the response it get login page of the rest services.is this issue related to cross domain or what please help.I haven't check if my proxy is working , question is how do i check it. I think it should be working since in IE when i use localhost instead of my IP it works fine.In mozilla in firebug when i check i see response being login page for rest service.I am running my proxy server in my Websphere which is running in port 9080 , my webserver is apache http server which is running at 80 where my arcgis server is running in other machine at port 6080Proxy server : WebSphere
proxy url : localhost:9080/proxy/proxy.jsp
web server : apache
web server url : localhost
Arcgis server:<some-ip>:6080
Below is completer code
<!DOCTYPE html>
<html>
<head>
<meta http-equiv="X-UA-Compatible" content="IE=7, IE=9, IE=10">
<!--The viewport meta tag is used to improve the presentation and behavior of the samples
on iOS devices-->
<title>FeatureLayer On Demand</title>
<link rel="stylesheet" href="http://js.arcgis.com/3.6/js/dojo/dijit/themes/claro/claro.css">
<link rel="stylesheet" href="http://js.arcgis.com/3.6/js/esri/css/esri.css">
<style>
html, body, #mapDiv {
padding:0;
margin:0;
height:100%;
</style>
<script src="http://js.arcgis.com/3.6/"></script>
<script>
var map,featureLayer;
require(["dojo/on", "esri/map", "esri/layers/ArcGISDynamicMapServiceLayer", "esri/InfoTemplate", "esri/layers/FeatureLayer",
"esri/symbols/SimpleFillSymbol", "esri/symbols/SimpleLineSymbol", "dojo/_base/Color", "esri/graphic",
"dojo/parser", "dojo/domReady!"
], function(
on,Map, ArcGISDynamicMapServiceLayer, InfoTemplate, FeatureLayer, SimpleFillSymbol, SimpleLineSymbol, Color, Graphic,
parser
parser.parse();
esri.config.defaults.io.proxyUrl = "http://localhost:9080/proxy/proxy.jsp";
var initExtent = new esri.geometry.Extent({"xmin":-21744805.806561172,"ymin":-4911537.689490959,"xmax":3302079.6219187006,"ymax":13090911.21222895,"spatialReference":{"wkid":102100}});
map = new Map("mapDiv", {
extent: initExtent
var WorldCountries = new ArcGISDynamicMapServiceLayer("http://10.32.9.106:6080/arcgis/rest/services/KX_Mapping/World_Countries_ESRI_WGS84/MapServer");
WorldCountries.setDisableClientCaching(true);
WorldCountries.setOpacity(0.75);
map.addLayer(WorldCountries);
showCountries();
map.on("load", initOperationalLayer);
function initOperationalLayer() {
featureLayer = new FeatureLayer("http://10.32.9.106:6080/arcgis/rest/services/KX_Mapping/World_Countries_ESRI_WGS84/MapServer/0",{
mode: esri.layers.FeatureLayer.MODE_SELECTION,
outFields: ["*"],
opacity: 0.75
var sfs = new SimpleFillSymbol(SimpleFillSymbol.STYLE_FORWARD_DIAGONAL, new SimpleLineSymbol(SimpleLineSymbol.STYLE_SOLID, new Color([255, 0, 0]), 2), new Color([255, 255, 0, 0.5]));
featureLayer.setSelectionSymbol(sfs);
map.addLayer(featureLayer);
map.infoWindow.resize(250,350);
on(map,"click", function(evt){
requestData(evt);
/*var query = new esri.tasks.Query();
query.geometry = evt.mapPoint;
featureLayer.selectFeatures(query,esri.layers.FeatureLayer.SELECTION_NEW, function (features){
map.infoWindow.setTitle("Country Information");
map.infoWindow.setContent("Country Name: " + features[0].attributes.COUNTRY);
map.infoWindow.show(evt.screenPoint,map.getInfoWindowAnchor(evt.screenPoint));
function showCountries(){
var queryTask = new esri.tasks.QueryTask("http://10.32.9.106:6080/arcgis/rest/services/KX_Mapping/World_Countries_ESRI_WGS84/MapServer/0");
//build query filter
console.log(" showCountries");
query.returnGeometry = true;
query.maxAllowableOffset=calcOffset();
query.where = "CNTRY_NAME IN ('India','Brazil','Italy','Australia','France','Libya','Russia','Ukraine','United States','Canada','Zimbabwe','Zambia','Yemen','Vietnam','Venezuela','Vanuatu','Uzbekistan','Uruguay','United States Minor Outlying Islands','United Kingdom','United Arab Emirates','Uganda','Tuvalu','Turks and Caicos Islands','Turkmenistan','Tajikistan','Turkey','Tunisia','Trinidad & Tobago','Tonga','Togo','Timor-Leste','Turkmenistan','Thailand','Tanzania','Palestinian Territory','Panama','Papua New Guinea','Paraguay','Poland','Portugal','Qatar','Romania','Greenland','Mexico','South Africa','South Korea','Spain','Sudan','Sri Lanka','Switzerland','Sweden','St. Vincent & the Grenadines','St. Pierre & Miquelon','Singapore','Indonesia','Colombia','Congo, DRC','Cook Is.','Costa Rica','Croatia','Cyprus','Czech Republic','Cameroon','Democratic Republic of the Congo','Antarctica','Armenia','Austria','North Korea','Romania','Rwanda','Norway','Monaco','Mauritania','Mauritius','Madagascar','Isle of Man','Iceland','Hungary','Germany','Antigua & Barbuda','Azerbaijan','Barbados','Belarus','Belgium','Bermuda','Bhutan','Bosnia & Herzegovina','British Indian Ocean Territory','British Virgin Is.','Central African Republic','Chad','Chile','Christmas I.','Egypt','Ethiopia','Finland','Vatican City','Western Sahara','Syria','Pakistan','Guyana','Mongolia','Nepal','Palau','Jamaica','Italy','Isreal','Fiji','Bermuda','Bhutan','Bolivia','The Bahamas','The Gambia','Montserrat','Mozambique','Morocco','Moldova','Kazakhstan','Myanmar','Sudan','Argentina','Bolivia','Algeria','Niger','Mali','Bolivia','Saudi Arabia','Botswana','Angola')";
query.spatialRelationship = esri.tasks.Query.SPATIAL_REL_CONTAINS;
//query.spatialRelationship = esri.tasks.Query.SPATIAL_REL_INTERSECTS;
var spRef = new esri.SpatialReference({wkid : 102100});
query.outSpatialReference = spRef; // Doesn't work
//query.outSpatialReference = map.spatialReference; // Doesn't work either
infoTemplate = new esri.InfoTemplate("Alert", "Alert for Re-insurance");
console.log(" infoTemplate "+infoTemplate);
dojo.connect(queryTask, "onComplete", function(featureSet) {
try{
console.log(" query complete");
var symbol0 = new esri.symbol.SimpleFillSymbol().setColor(new dojo.Color([255, 0, 0, 0.9]));
dojo.forEach(featureSet.features,function(feature){
//alert('feature'+feature);
var graphic = feature;
graphic.setSymbol(symbol0);
//alert("infoTemplate"+infoTemplate);
graphic.setInfoTemplate(infoTemplate);
//alert("graphic"+graphic);
//alert("map.graphics"+map.graphics);
map.graphics.add(graphic);
}catch(e){
alert("e"+e);
queryTask.execute(query);
function requestData(evt){
try{
console.log(" request data");
dojo.xhrGet({
url: "http://earthquake.usgs.gov/earthquakes/feed/geojson/1.0/week",
handleAs: 'json',
load: function(data){
map.infoWindow.setTitle("data[0].properties.place");
map.infoWindow.setContent("data[0].properties.mag");
error: dojo.hitch(this, "failure")
}catch(e){
console.log(e);
function showData(){
console.log("in showdata");
function failure(){
console.log("failed");
function calcOffset() {
return (map.extent.getWidth() / map.width);
// console.log('extent changed...maxOffset: ', globals.maxOffset);
</script>
</head>
<body class="claro">
<div id="mapDiv">
</div>
</body>
</html>
